488 - Removing screws on brake pedal? Should be easier | FerrariChat
488 Removing screws on brake pedal? Should be easier
Discussion in '458 Italia/488/F8' started by DiamondDog, Oct 22, 2021.
  1. DiamondDog
    DiamondDog Formula 3
    Aug 29, 2021
    1,461
    Orange County, CA
    Thought this would be easy. I want to move my brake pedal to the left as I have wide feet. Thought I would just unscrew and be done.
    These screws are in there super tight. Afraid of breaking or stripping something. Confirming this is just a standard hex socket? Using a small socket wrench and it won't budge
    Planning on replacing dead pedal me those screws unscrew easily.
    Any advice? Image Unavailable, Please Login
  2. RayJohns
    RayJohns F1 Veteran
    7,920
    West Coast
    Ray
    They should be metric hex yes. I believe they are on with loctite if I'm not mistaken. You might want to use a heat gun or small torch and get a little heat into the mix
    Ray
    ShadowLAP and whatheheck like this.
  3. toomanymodz
    toomanymodz Rookie
    Aug 18, 2007
    33
    FL
    Matt
    I ran into the same issue. Afraid of buggering up the hex bolts, I left them alone. I wear "special" shoes for when I want to drive the F car. One pair is made by Van's. The other is a pair of Bugatti brand leather sneakers that I purchased while on vacation in Germany quite a number of years ago. I normally wear DC Shoes (size 12) but they absolutely won't fit the pedals! Good luck!
  4. Viperjoe
    Viperjoe F1 Rookie
    I had mine off several times. Super easy. Hold the Allen hex (bolt) stationary while turning the hex nut on the back side.
    Rexcat458 likes this.
  5. Stams
    Stams Formula Junior
    550
    Colorado
    Sean
    When I added my Hill dead pedal, the bolts were cross threaded - I assume during assembly at factory. Just FYI and be aware.
  6. DiamondDog
    Aug 29, 2021
    1,461
    Orange County, CA
    You mean use your head? Duh.
    What did you use for the bolt on right? Hard to manuver on that side of the pedal
  7. Viperjoe
    Viperjoe F1 Rookie
    10mm socket on a 1/4” drive ratchet.
