Removing side markers | FerrariChat
Discussion in '348/355' started by robin's308, Jul 25, 2007.
  1. robin's308
    robin's308 Formula Junior
    Jan 14, 2006
    306
    Honolulu
    Hello guys, how do you remove the U.S spec Front side markers? i have a feeling they don't just pop out, do the bumpers have to come off?
  2. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    You would like to hope they would pop off to replace your bulb rather than go to the trouble of removing your bumper. Similar ones I have done I would use a small flat blade screwdriver and try to pry it up, try either end as most times they have a locking tang and only pry up from one end. Failing that turn your wheel one way and remove the inside wheel liner and have a look from the back ;)
  3. robin's308
    Jan 14, 2006
    306
    Honolulu
    hmmm, if it doesn't pry off then i will have a look in that compartment in front of the wheel..... if the bumper does indeed have to come off that would be a very stupid design.
  4. robin's308
    Jan 14, 2006
    306
    Honolulu
    has anyone removed these before?
    suleyman likes this.
