Removing Stuck on Gaskets | FerrariChat
Discussion in 'Technical Q&A' started by Sean F., Jan 12, 2009.
  1. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,066
    Kansas
    Sean F
    Got the transmission and oil sump covers off and most of the gaskets, but a small amount is stubornly refusing to come off.
    Any suggestions. Didn't want to use a metal scraper for fear of scratching the metal, but there are small bits that are crushed pretty flat (but you can still feel them with your finger). I don't want to simply throw some RTV over it to have the new gaskets leak. The old ones did that which is why I'm doing this in the first place.
    tks
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #2 2NA, Jan 12, 2009
    Some aerosol carb cleaner and a single-edge razor blade scraper. A small wire brush will help you around protruding studs.
    Be careful not to damage the surface (or your fingers).
  3. gidge348
    gidge348 Formula Junior
    Dec 12, 2008
    343
    Perth West Australia
    Ian Wood
    Acrylic thinner, coarse cloth (toweling/denim) and elbow grease.
    Be careful not to get it on any O rings or seals you want to keep.
  4. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    There's also some aerosol "Chisel Gasket Remover" (that's really the name :)) available from my favorite supplier ... Mcmaster Carr. I think the stuff is pretty much aircraft paint stripper and the latest can doesn't seem as malicious.
    Cheers
  5. Enzo
    Enzo F1 Rookie
    Feb 14, 2002
    4,089
    MinneSOta
    Pat Pasqualini
    a good tool to use is an outlet or lightswitch plate. Buy the cheap ones at home depot and they work great.
  6. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    I agree on using one of those spray gasket removers. Just be careful where you get it. I found you have to let it sit for a while to soften the gasket material. Also, I have a couple of plastic spackle knives/paint scrapers that I use, that work really well, and a plastic golf shoe brush with very stiff bristles. I also found that Scotchbrite pads work well too. You just need to be patient and persistent. And if the gasket remover won't stay in place, try spraying a paper towel or piece of cloth and putting it in on the spot you are working on, let it sit for an hour or two, then hit it with the scraper. If all else fails, I've used a wood chisel with a very sharp edge, or a razor blade in one of those scraper handles to carefully work at the remaining gasket material. Just be careful not to gouge the surface.
  7. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    I recently tried a gasket remover made by Wurth and it really did a great job. It took a couple of applications, but, after each application, using a putty knife with light application so as to not damage the sealing surface took the gasket off. I'll look-up the product name when I get home if you are interested.
  8. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    I would suggest Permatex Gasket Remover. Item # 80646 (4MA). It's spray-on and may take several applications, but it's worked well for me.
  9. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,066
    Kansas
    Sean F
    I tried the spray on gasket remover and that's what' gotten me to the point I'm at now, at least with the engine side. The gasket came right off the oil sump, but on the transmission it STUCK to the sump instead of the cover so spraying it on will be difficult.
    I'll try the plastic wheel brush someone suggested above with my dremel tool. I'll test it out first to be sure I won't scratch the metal, then finish off with some scotch bright.
    thanks all...
  10. fatbillybob
    Aug 10, 2002
    28,642
    socal
    If really bad I take the studs out because it is easier to clean a flat surface and faster to in/out the studs, then use a paint scraper putty knife. No damage results. for the fine stuff I use a single edge razor blade scratched perpendicular to the deck.
