Removing transaxle flange? | FerrariChat
Discussion in '308/328' started by thorn, Dec 4, 2017.
  1. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    1985 QV Euro, Left-hand drive.
    I just want to double-check that I'm doing this right, before I break something.
    I'm rebuilding the CV joints on the passenger side, following Birdman's excellent tutorial. I'm at the point that I believe I need to remove the transaxle flange, so that a seal can be replaced. But, I can't get the flange off the gear shaft and gear box. It moves about 1/16th of an inch, then feels like it's hung up. Or to say differently, it feels like it's not supposed to come off... like there's something else holding it on.
    Pic attached, to show the thing I'm talking about. The car is in gear, btw.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,605
    San Carlos, CA
    Mitchell Le
    Don't be timid. Pull on it. Nothing is holding it back but your fear.
    thorn likes this.
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    Tap tap tap gently with a small hammer along the edge of the flange on the back and spray some penetrant lube in the splines.
  4. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Dang, this is weird. It's not physically stuck on the shaft. I can slide the housing in and out a few mm easily... no effort at all, but then it just stops.
    Will try some PB oil and some gentle rubber mallet.
  5. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Gear Puller to the rescue. It's off. And undamaged.
    Thanks guys! :D
    tuttebenne likes this.
