removing USA smog equipment from a Dino | FerrariChat
Discussion in '206/246' started by jnk, Oct 11, 2014.
  1. jnk
    jnk Formula Junior
    Nov 12, 2010
    345
    What are then advantages and disadvantages of having all of the USA smog equipment removed during an engine rebuild.
  2. Rifledriver
    37,099
    Being that the Dino is now a collector or investment grade car they are worth far more complete and intact in every way including the smog equipment.
    Have a look around. I doubt you will find a US version Daytona without all it's smog equipment installed.
  3. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,798
    Southern California
    From what I understand, if you show your Dino at an FCA concours they will deduct points and if you want to get Ferrari Classische Certified everything has to be as it left the factory. In both instances I don't think they need to be functional but need to visually be correct. Those parts are really valuable and can be hard to find. A good philosophy to consider is to make any modification invisible or easy (bolt on/bolt off) to reverse. Just my opinion.
    Freeman
  4. TTR
    TTR F1 Veteran Rossa Subscribed
    Mar 29, 2007
    5,890
    Riverside, CA
    Timo
    Sorry to prove you incorrect Mr. Crall, but surprisingly many around, some even within my arms reach. :)
    To jnk: Only advantage might be slight weight loss and perhaps "cleaner" engine bay appearance, but all other things being equal, probably nothing noticeable performance-wise.
    And if removed, paraphrasing Mr. Cralls advise, do not discard any components or parts so they can be re-installed at later date, if so desired.
  5. dm_n_stuff
    dm_n_stuff Four Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2003
    43,725
    26.806311,-81.755805
    Dave M.
    Disadvantage to leaving it attached, I seem to recall, is the danger that the pump seizes with some downstream negative effect. I don't remember the details, but I think the smog pump seizing can be a real bummer to other major components.
    OR do I have it confused with a 1971 MGB?
    I think you can loop it out of the system with a shorter belt, and avoid any issues without physically removing it from the car. Or am I confused again with that dang MGB?
    I know I messed with smog pumps on both cars, just been too long and I can't recall which pump was which anymore.
    D
  6. racerboy9
    racerboy9 F1 Rookie Silver Subscribed
    Nov 3, 2003
    2,649
    Smog pump is driven off a coupling on the back of the special alternator. You can just remove the coupling half from the alternator and your no longer connected to the smog pump.
  7. mar3kl
    mar3kl Formula Junior
    Nov 17, 2011
    470
    Silicon Valley
    Mark
    MGB pump seizing will trash the belt connecting it to the crank, but that's about it. It's much less sophisticated than the Dino's. And no one cares if you rip the smog equipment off the MGB :)
  8. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    My recollection is that removing the belt from a smog pump but leaving it attached to the exhaust manifold causes the pump to fill up with carbon and corrosion-inducing moisture from the exhaust, thus ruining it and causing the seizing mentioned.
    If you never plan to ever attach a belt to it again that shouldn't matter, but then it wouldn't be correct for concours and you'd probably lose points. So you might want to leave it attached. It probably takes like 1 hp to drive it, so negligible on these cars.
    My Dino is a Euro version, but did the US version have EGR? Depending on how it is done I believe that can affect the mixture.
