Removing water washer bottle in a 575 | FerrariChat
Discussion in '456/550/575' started by Ozeskiman, May 14, 2021.
  1. Ozeskiman
    Ozeskiman Karting
    May 15, 2016
    76
    Melbourne
    Tony
    Can anyone shed light on the easiest way to remove a leaking water washer bottle in my 575. I replaced it a few years back and it's now leaking again. I'm guessing its a seal or hose fault as it empties out completely. I tried getting to it by removing the RH light assembly ( it's a RHD car in case that makes a difference ) but there is a metal plate under the light that prevents access to the bottle, even though its clearly visible. If I try to remove this plate I find it is spot welded to the top section of the front guard, so I don't wish to try removing the guard. Is it accessible via the front wheel arch, or from underneath once the trays are removed? Any thoughts, suggestions greatly appreciated.
  2. Qavion
    Qavion F1 World Champ
    14,343
    Ian Riddell
    I see it's quite different from the 550. Looks quite large, too.
    I replaced the washer bottle on my F355 recently (similar style to the 550). The plastic gets pretty brittle over time and overtorque-ing the mounting bolts cracks the mounting lugs (and can damage the bottle itself).
    Looking at the rear 575 mounting lug, it looks like it's mounted to something solid underneath the bottle. I think I'd go in from the wheel arch (if only for "reconnaissance")
  3. tazandjan
    39,195
    First step in changing the pump or the tank is "Remove the front bumper." according to the WSM.
    Qavion likes this.
  4. Qavion
    14,343
    Ian Riddell
    I wonder if that's optional, depending on how long your arm are :D
    Seems like the 575 WSM is a little more informative than the owners manual. I couldn't even find a refill procedure in that.
  5. Ozeskiman
    Ozeskiman Karting
    May 15, 2016
    76
    Melbourne
    Tony
    Removing the bumper seems onerous. Typical Ferrari design I guess. I'll be taking it to either my dealer or my body shop guys so I'll update later. Thanks for your thoughts.
