Renaissance Man episode | FerrariChat
Discussion in 'Aviation Chat' started by davidgoerndt, Mar 26, 2012.
  1. davidgoerndt
    davidgoerndt Formula 3
    Oct 25, 2004
    1,420
    Orlando, FL
    David Goerndt
    I caught a repeat episode of this show on velocity and they were discussing the RR Merlin engine and the planes that used it, very informative. Sorry if this is a re-post,
  2. tritone
    tritone F1 Veteran
    7,199
    On the Rock
    James
    Related; if you want to know all about Merlins & unlimited hydros, Dixon Smith is giving a great presentation at the Hydroplane Museum on May 19. Will trace their use from the early '50's thru to the end of the piston era, and on into vintage. There will be motors on display; don't know about fire-ups.....
    http://thunderboats.ning.com/
  3. Gatorrari
    Gatorrari F1 World Champ
    16,459
    Georgia
    Jim Pernikoff
    I've met Dixon and this should be a great presentation; too bad I'm unlikely to be able to make it out to Seattle then. The hydros lost something when they switched to turbine engines; I still have fond memories of full fields of Unlimiteds on Lake Washington all powered by V-12 aircraft engines! Now THAT was thunder!
  4. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    #4 toggie, Mar 26, 2012
  5. chris_columbia
    chris_columbia Formula Junior
    858
    Columbia MD
    Chris
    Did you get a picture of the other monster a few feet from the merlin. P&W R-4360. 7 cyl radial, four rows deep! 72 liters makes the 27L Merlin look wimpy.
  6. Tcar
    Tcar F1 Rookie
    7 x 4 = 28 cylinders... 56 sparkplugs!
    4,360 is the model, but also the cu. in. displacement!
    Weighed about 4,000 lbs., but turbocharged and supercharged (both) it had about 4,500 hp.
    Makes the Merlin look small.
    Was developed at the end of the war, so was never used during the war.
  7. Gatorrari
    16,459
    Georgia
    Jim Pernikoff
