355 - Repair A/C Compressor? | FerrariChat
355 Repair A/C Compressor?
Discussion in '348/355' started by watkinsgt, Apr 12, 2022.
  1. watkinsgt
    watkinsgt Karting
    Feb 4, 2008
    215
    My '99 355 is diagnosed with an electrical short in the a/c compressor. Cost to replace compressor is $3k. Can shorts in a/c compressors be repaired? If so - by whom? Are a/c compressor failures heat related? I have a 'heat deflection shield' installed. Are compressors ever wrapped in 'heat blankets'? Are there better solutions? Thanks.
  2. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    If it is electrical that would be the drive clutch not the actual compressor. That can be replaced and the quote you have is very steep. Check with a regular AC shop to find out the repair cost. There is nothing unique about a Ferrari compressor other than the pulley.
  3. EFerrari34
    EFerrari34 Formula Junior
    535
    Dallas, Tx
    Timothy
    Ricambi has them for around $600. Solution!
    Mike Morrissey likes this.
  4. fatbillybob
    Aug 10, 2002
    28,967
    socal
    What is amazing is “this time”. Everyone is charging stupid money for everything and seeing if clients blink.
    26street likes this.
  5. 26street
    26street Formula Junior
    Jan 30, 2021
    466
    Westchester New York
    Mark k
    Does the driven part of the compressor turn
    ( the center clutch plate that doesn’t turn with the A/C off ) if it does turn with little or no resistance you will just need to replace the magnet clutch and plate which should not cost 3k or $600
    But if it doesn’t turn by hand then a compressor is needed and maybe a few other parts (receive a dryer, expansion valve) and a flush of the system because if the compressor let go small pieces can still be floating around in the lines then I can see the cost going up
    A good A/C shop is well equipped to handle this type of work at a lower price then Ferrari dealer or even a independent Ferrari specialty shop which I have seen both of these places send the car out or have a guy come in for the A/C repairs
    Don’t know where you are but ask around here if anyone is in your area and knows a place
  6. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I replaced mine myself. Other than getting the car on the lift and working your hands around tight places there is nothing difficult about it. I bought my new ac unit from an outfit in FL that I can’t recall the name of right now. Compressor and dryer around $800 IRC. Recharge system around $100.
  7. m.stojanovic
    m.stojanovic F1 Rookie
    3,217
    Serbia - Niš
    Miroljub Stojanovic
  8. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    $3k, damn.
  9. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
