Repair costs | FerrariChat
Repair costs
Discussion in 'United Kingdom' started by MarcoB, Mar 14, 2019.
  1. MarcoB
    MarcoB Rookie
    Dec 30, 2017
    11
    Mark B
    hi everyone
    I have been quoted on the below work, wondered if anyone had views on some of the pricing, it’s clearly a big bill so wanted to see what people thought.
    1. Alarm LED permanently on. Req’s a new siren - £506.63
    2. Drivers wiper arm worn and fouling bonnet and scuttle panel. £487.72
    3. Passenger seat will req removal to address rattle as reported by customer.£108.00
    4. Drivers check strap broken. £198.02
    5. Drivers sun visor loose and falls down.£54.00
    6. Black paint peeling off of oil separator.£216.00 plus paint
    7. Slight chatter from inlet manifold butterflies on idle. Report
    8. Lh washer jet blocked. £2.58
    9. Both A pillar weather seals misaligned and causing wind noise as reported by customer, adjustment of the glass is req’d and possibly new seals. £858.41
    10. All 4 tyres are worn . approx 3-3.5mm left. They’re approx 6 years old.
    11. Several wheel bolts rusty. £57.00 each bolt
    12. Headlamp washers inoperative. Suspect pump? £153.23 plus parts
    13. Engine oil overfilled. – part of the service
    14. Both cooling fans noisy LH more so. these are prone to seizure so I would recommend they’re replaced. £459.64
    15. Pressure tested cooling system, Found coolant hose clip corroded and leaking as reported. replace clip and refill system/test again. Replaced clip, water pump itself is leaking awaiting to see if can price a used unit otherwise cost to split apart and rebuild is £620.57
    16. Emergency fuel flap T lever missing and release cable is loose and adrift. req’s new lever and re-securing. £11.40
    17. Low tone horn inop, There are 2 and only 1 is working. £295.22
    18. Oil leaking from A/C compressor, Not excessive and common on 360’s…… Report and monitor.
    19. Excessive play in RHF lower ball joint, Dust covers ok as these have been replaced recently by GVE. Ball joint should of been done at the same time ideally. £371.54
    20. Both rear track control arm joint dust covers split and perished. Unfortunately they don’t come separate so this will mean two complete arms. £1606.08
    21. Both front track rod end dust covers split and perished, req’s two new ends as they don’t also do not come separate. £921.91
    22. All four suspension springs are very rusty at the base of the spring, These are prone to snapping when rusty so I would recommend these are replaced. £1351.80
    23. There is evidence of oil loss from the steering rack from both outer bellows …However according to the last service invoice the rack has been replaced .
    It looks like a second hand rack or an overhauled item that has been fitted ? Investigate source of leak and report back to customer. £54.00 to diagnose
    24. All four brake discs approx half worn and in poor condition on back faces ( Rusty and scored ) Report these for now as theres life in the pads. Recommend new discs next pad change.
    25. Gear box still has the early type support bush fitted which is also worn and split. ( Load bearing component ) £542.96
    26. Alloy clutch fluid block on side of Gearbox cracked and is weeping slightly. common problem which can fail causing complete loss of clutch pedal. Early type pre modified block fitted. £205.74
    27. Coolant pipe securing bracket located behind rear bulk head panel has snapped leaving the metal coolant transfer pipe loose and insecure. Fabricate and fit new bracket.£216.00
    28. Would recommend new cam belts, Auxiliary belts and tensioner bearings as I suspect these haven’t been done in the last 3 yearrs? Customer to confirm last belt change according to service history. £1375.15
    29. Fairly heavy oil leak from Left hand bank cam cover gasket/seal? Investigate and confirm. £408.95
    30. I would recommend vehicle has an Annual service as last service was done 2017.. According the last invoice the vehicle only had a oil and filter change ( 1.5hrs ) and a Major service inspection. ( 2.0hrs ) please note!!
    Keen to do work but just trying to understand how it looks?
    Any help welcome
    M
  2. Dalesoden
    Dalesoden Rookie
    Jan 7, 2019
    10
    Daleq
    Hi Marco,
    Where abouts are you located?
    Pop me a PM through, I may be able to help you out with this.
  3. MarcoB
    MarcoB Rookie
    Dec 30, 2017
    11
    Mark B
    How do you send a Pm, it is not clear to me!!
  4. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,667
    South East
    Jimmie
    So this looks like a quote (possibly as part of a PPI) to do some long overdue work on a recently purchased 360 - many of the items are standard requirements over time eg belts tyres alarm led ball joints
    Depending on where you are there may be better ways than involving a main dealer
    I think you need to not be new members with few posts to pm (now called 'Conversation' here)
  5. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,582
    Grant
    Where are you located Mark?
  6. A348W
    A348W Formula 3
    Jun 28, 2017
    1,846
    North Wiltshire, UK
    As above; sounds like a pile of long overdue maintenance that has been deferred by previous owners and its now yours to deal with!
    A lot depends on how handy you are with the spanners. Also how much you want some of the rattles etc sorted. There is nothing on there that people don’t do themselves.
    If money is a consideration I’d suggest getting all the mechanics sorted now. You can get the rattles and wind noise sorted later.
    If you want more specific insight to costs etc; try joining Club Scuderia forum. There are a few 360 owners who are very knowledgeable.
    Good luck and enjoy.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Have a look on. Superperformance uk web site re item 20 and 21. Not sure if right covers but worth a look . Other items listed as well
  8. RegW
    RegW Karting
    Aug 8, 2017
    62
    London
