Repairing/Polishing Differential Ring Gear | FerrariChat
Discussion in 'Technical Q&A' started by Drew Altemara, Jun 10, 2006.
  1. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    #1 Drew Altemara, Jun 10, 2006
    The differential side carrier plate and spacer failed on my 512BB recently leaving the pieces inside case and leaving the differential free to walk around until I had time to get it out of gear.
    The ring gear appears to have been damaged as well as the differential itself
    The box has been sent to CA for rebuilding. I was wondering what the prospects of saving the ring gear were as they are very hard to obtain?
    Appreciate you comments.
    Drew Altemarahe differential itself.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Oooooooooh man I feel your pain, really I do. Man that is nasty and the race cracked. I thought I was the only one who had a cracked bearing race. Shoot yours completely busted in half, mine only semi-cracked.
    I hate to tell you this but, you're gonna have to get a new one, or new used if you can, and they are not cheap. They only sell these things in a set. Before you order stuff, take it from me, go through EVERYTHING and then order what you need. Other wise you'll be half way through the project and find out that you need to order something else, and that will only prolong the time it takes for you to get back on the road.
    If you can find used then that's the way to go, but if you can't then Dan is the man with the master plan http://www.ricambiamerica.com/. All in all, you're looking at a few grand before things are all done.
  3. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    As for the polishing you could try these guys. http://www.procryo.com/index.html
    I called them up when I first started the rebuild on my box. They had some pretty good prices, and the turn around time was a couple of days. I would send them a pic of the ring gear and see what they tell you. But in my opinion you'll be better off getting a used set if you can.
  4. Drew Altemara
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    Yea, what a strange catostrophic faiure. First time in over 20 years of ownership I had a Ferrari let me down. Wish I could tell a better story but it happened at 5mph, making a left hand turn after the car was totally warmed up. Go figure.
    I am told there are no ring and pinions left for a BB512 in the world.
    Ted Rutland secured a used BB transmission for me and we are sending both transmissions off to CA (Rod Drew). We will use the parts from the used case (ring/pinion and differential - maybe) to make one good one. Of course while everything is out might as well replace the syncros and seals. Ted will inventory the parts that are left.
    It hurts me to even look at the pictures.
    Thanks for your comments.
    Drew Altemara
  5. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    You could REM treat it and run it. The damage isn't on the drive or coast surface. If it fails, you can have one made. Gear and Machine Specialty, Memphis, TN. Glenn Sipe.
    Goodness, folks, there are a lot of NLA R&P's around. I'm having one made for my wife's Siata now...
    -Peter
  6. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Can a new ring gear be made and matched to an existing pinion? Can they be re-heat treated? I would imagine a new pinion shaft would be big $$$
    Unrelated car, but not entirely. I used to own a SAAB SPG, and did a few upgrades for more power. Dont know what it had but was definetly well over 200 HP. But the gearbox was originally designed for a 100 HP engine, and well, it stripped off teeth from the ring and the pinion both. Funny this stuff always breaks at low speed, low power.
  7. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Your ring gear is not that bad and can be repaired. The burrs can be smoothed with a dremel and polished with a rubberized abrasive wheel on the dremel. you will never know the difference when put back together, you will not even hear any gear noise out of the ordinary.
    I am totally serious, your damage is cosmetic as this ring gear is very hard and tough and you should have no reservations about a fix.
  8. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,958
    The Cold North
    Tom
    Ring gear looks to be repairable as stated above. The carrier will need to be replaced. The Testarossa diffs fail in the same manner. I replace them with a unit from Modena Engineering, its a fantastic unit that will out last the car. The diff bearings can be sourced from SKF or Timkin, they come with the races. The shims can be made very easily by a machine shop which I have done in the past.
    Its not the side cover that fails, its the diff that comes apart and puts huge pressure on either the right or left side cover. Either way one always gives way when the diff comes apart. I have found most times its the left side that blows apart leaving the right side intact...yours is the opposite obviously.
  9. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    "Can a new ring gear be made and matched to an existing pinion?"
    Nope, always have to be done in pairs (at least the hypoid ones).
    Might be able to do the helical final drive gears (308/328) one at a time, though.
    Still think this one is salvagable.
  10. Drew Altemara
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    Thanks for the replies guys. When the transmission gets to California I am going to have a detailed discussion with Ron Drew's shop who is doing the work. They do a lot of work for Rutlands piecing back TR transmissions which Ted then inventories and sells.
    Will keep you updated. But I really appreciate your comments and will ask them to review them.
    Drew
  11. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    And don't forget the bearings. ;)
  12. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Hey Ernie, show us a picture of your semi-cracked race.
  13. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
  14. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
  15. Drew Altemara
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    No prior notice at all. No noise, smooth as silk prior to breaking. Just "bang" at 5mph.
    Thought a cam belt let loose. Lots of smoke from the engine compartment from Royal Purple spilling out the RHS differential side carrier onto the hot exhaust. Got the car stopped in about 10 seconds or 50-60 feet. Deep, deep rumble, at first thought the exhaust was dragging then realized it was the transmission/differential grinding away at the case.
    I do not know if the side carrier failed and cracked the differential or if the differential failed and put pressure on the side carrier.
    Will keep you informed.
    Drew
  16. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    Drew,
    Just playing devils advocate but I know you changed your gear oil a few months ago to Royal Purple do you think their is any coincidence if the diff exploded?
  17. Drew Altemara
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    I put Royal Purple in the gear box on Jan 05 and checked the level as part of my routine spring maintenance in March 06.
    I do not think this had anything to do with the type of gear oil in the box.
    I think it was just my time and turn to pay.
    I am told that this type failure was seen on a number of early TR's. In that the differential welds would fail and put pressure on the side carrier which then exploded. However it is rare on a Boxer.
    This is the first time in well over 20 years of ownership that I've had a major issue with a Ferrari.
    Just my turn I guess.
    Drew
  18. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    I think owning these cars long enough something will happen sooner or later just the laws of averages, unless you never drive them, or just baby them but what fun is that.
    One of the disadvantages of such a rare car as the BB is the scarcity and expense of parts but the guys that own rare Ferraris from the 50s and 60s would love to have as many parts we have left for BBs from various sources so its relative. It would be nice to find a way to remanufacture some of these rare parts to reduce cost and down time when something happens though.
    On JRVs site he mentioned the early 365BBs have a known soft ring and pinion though improved on the 512 FWIW.
    Can they repair your diff and reweld it or do you need a replacement?
  19. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    Here's a guy that makes them from scratch, just did a Daytona R&P and has made Boxer R&Ps before, the price goes down depending on how many made but it would take at least 5 to do it with a cad, he said the BBs are a pain as the gearing is a left turn vs regular, takes 10 weeks $6300
    Machines them out of solid billet alloy 9310 I believe vs slightly softer OEM Ferrari alloy.
    http://www.specialtygear.com/index.html
  20. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,339
    Dumpster Fire #31
    SMG
    Per EPI,
    "The alloy AISI-9310H is a high-quality, high hardenability, high-toughness, case-hardening steel. It is a very low carbon steel, containing only 0.10% (that's the meaning of the "10" in 9310), and commonly referred to as "10 points of carbon".
    This alloy was specifically designed to be a case-hardening steel for use in applications which require high surface strength (achieved by case-hardening) combined with very high core toughness resulting from the low-carbon core. It is intended for use in extreme applications, where high contact stress is combined with high shock and impact loading.
    In order to achieve the combination of surface hardness and depth of case required for a gear tooth or the inner race of a roller-clutch for example, a substantial amount of carbon must be added to the outer surface of the material, typically by the carburizing process.
    In this process, the steel is heated to 1700°F and soaked for several hours at that temperature in an environment which is rich in carbon, followed by quenching and tempering. The carburizing process can produce a surface hardness in 9310 from 59-61 HRc (Hardness, Rockwell-C scale), and case depths as high as 0.060".
    Because of the low carbon content of this steel, the as-quenched hardness (core and on-case-hardened areas) falls in the 32-38 HRc range, depending on whether the material is toward the low or high side of the allowable carbon content range.
    AISI-9310H is typically used for premium-quality steel gears, frequently in the aircraft industry."
    might explain the cost, however low volume is expensive no matter what. something i deal with on ferrari parts as well. youre american iron is so prolific that cost is absorbed on the high number of units, not to mention even thier falure rate is high also, keeps the market going.
  21. ParadiseRoad
    ParadiseRoad Formula Junior
    Mar 26, 2006
    538
    Colorado
  22. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    Just talked to him quoted $2500-$3000 for 9310 which he said is aircraft grade a little overkill, gues he didn't have the Ferrari tax as the other guy.
  23. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,339
    Dumpster Fire #31
    SMG
    reproducing a part is easy enough with a CMM. from there it's onto CADCAM softeware and milling/machinig. shop hr rates and material costs make the bulk of your cost. heat treating is another step.
    "ferrari tax" is a funny one, i never tell any supplier or outsource the parts final destination as they sudenly see $$$$ and figure they want cut. we have honest vendors and manufactures here and the, well not so honest.
    here is another good source
    http://www.arrowgear.com/
    our rings are accutually spiral bevel gears, not easy.
  24. ParadiseRoad
    Mar 26, 2006
    538
    Colorado
    Did you notice the two sources are located in close proximity to each other? Perhaps the $6300 source takes your order, and has the part made at the $2500-$3000 source, and then charges you over double for the privilege of doing business with him.
  25. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    Could be but I am fairly sure the expensive guy does it in house, when I said Ferrari the price doubled and he got excited.
    Both machine the parts on a lathe hand made, probably the same way ferrari did it back then, it takes at least 5 pieces from what I was told to make it economical to use CAD.
