Replace Door Strikers | FerrariChat
Discussion in '348/355' started by RandyT, Sep 29, 2017.
  1. RandyT
    RandyT Formula Junior
    Aug 16, 2016
    258
    Calabasas, CA
    Randy T
    I need to replace my door strikers. Is there anything I should know before replacing them? Do I need to use Locktite on the bolts? Image Unavailable, Please Login
  2. RandyT
    Aug 16, 2016
    258
    Calabasas, CA
    Randy T
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I think you will find that the rear edges of your doors are sagging fairly significantly, most likely from people leaning on the doors when getting in and out. It is POSSIBLE to realign the doors to fit squarely into the openings, by carefully yanking the rear edge of the doors upwards. I wouldn't bother aligning the new pins with the old latches unless you want to see the same results. Your hinges (or the hinge pins) may be worn out beyond adjustment.
    Shouldn't the new pins have white plastic bushings on them?
