Replace Mondial 2,9l-engine with 348-engine | FerrariChat
Discussion in 'Technical Q&A' started by Jepson, Oct 18, 2005.
  1. Jepson
    Jepson Rookie
    Oct 18, 2005
    1
    Would it be possible to do so without any rebuilds?? Why I´m asking, is that I´m about to buy a Lancia Thema 8.32, that I´ve been told has the 348 engine, instead of the original 2,9l 32v Ferrari V8...but I´m a bit confused, because eveything looks like it was original...and I have no idea of how to id the engine, if it really is the 348 V8....can someone help me, please?
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,709
    South East
    Jimmie
    I'm pretty sure the Lancia engine is a slightly softer 328 (not 348) engine which would make the transfer easier but I'm not sure whether the mounts are different 328 vs 308 - actually even as I write I recall a friend who blew his 308 QV and had a 328 engine put in - hope this gives a little confidence if not actually technically very helpful !
  3. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,420
    E ' ' '/ F
    Enzo Gorlomi
    #3 GrigioGuy, Oct 18, 2005
  4. fmaderi
    fmaderi Formula Junior
    May 8, 2005
    258
    clearwater Fla/NY
    frank maderi
    nice looking package.are you going to use the gear box/final drive.they look abit different.
  5. Zertec
    Zertec Formula 3
    Oct 5, 2004
    1,335
    Singapore
    Clive Reed
    I believe that the Lancia version has a 90 degree crank rather than the 180 degree crank in the 308 engine.
    I could of course be mistaken as I am in Holland...
  6. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    All previous comments are correct....
    the Lancia is a reworked 3.0 QV with 90 degree crank. Output is from memory, 190BHP, but torque is about the same but lower in the RPM range.
    Since the 348 block is essentially the same as the 308/328, and has the same bore centres, there is no reason why you couldn't put a 348 in a 308/mondial. Only question I have is this: Why not put in a 355 engine? If you are going to go to the massive expense and difficulty of putting a 348 engine in, may as well do the 355 and have the extra 80 BHP. Now, a 308/mondial with 380 BHP sounds VERY nice..... Add the Aussie twin turbo kit, and then you have a $100K 700 horsepower mondial MONSTER.
    BTW - I'd upgrade the brakes :)
  7. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,067
    Kansas
    Sean F
    No no, the 90° crank is only in Australia, every else it's 180° ;)
  8. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    INCORRECT! In Australia it is either 270 or 360. You need to look at this from the correct perspective (ie downunder) :)
    BTW Australia used to be called New Holland about 300 years ago, so maybe Zertec is onto something....
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    The thing to do would be to bolt the Thema manifold to the Ferrari engine - look at those runners and TWO throttle bodies!
    I'm interested if anyone has a complete Thema manifold.....
  10. dell550
    dell550 Karting
    Aug 24, 2005
    209
    London
    george c
    the lancia 8:32 engine will not fit into any ferrari without major major reworking-it will not fit onto the gearbox as the bottom face has been machined differently along with a myriad of other small details. i know as i looked at this conversion for a customer of mine.I finally persuaded him to upgrade his 3.0 qv mondial to 3.2 with some high compression pistons and well worked heads along with the inlet manifolds and plenum from the lancia but without the restrictive K-Jet injection.Instead we modified the injector bosses to accept EFI injectors and run the whole lot with a motec ecu.This set up is due to be dynoed next month once we finish our 2-valve race engine developement which currently stands at 365 flywheel bhp and 265 odd lbs of torque-lots of driveability and 9000rpm allon carbs and two valves with CDi ignition
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Were 348 motors or transmissions **ever** used in any other production car of any make?
    How would one find such things?
  12. GrigioGuy
    Nov 26, 2001
    33,420
    E ' ' '/ F
    Enzo Gorlomi
    No, they weren't. Mondial Ts and 348s only.
  13. Harta320
    Harta320 Karting
    Nov 6, 2003
    169
    Sarasota, FL
    Bill Smith
    Dell 550,
    Where can you get that intake plenum and about how much would it cost? I am going to go to EFI this winter (308QV) and that intake would be perfect.
    Bill
  14. buzzm2005
    buzzm2005 Formula 3
    Aug 23, 2005
    1,739
    NYC
    Buzz
    Do tell more! Has anyone tried putting a 355 engine in a Mondial t? And what is this Aussie twin turbo kit?
  15. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    http://www.ferrarichat.com/forum/showthread.php?t=29754
    There is a lot of off topic noise in that thread, but the info is there. the car is an apparent monster, and the kit is in the 30+K range.
    As for putting a 355 donk in a mondial t, well, I have never heard of it, but that does not mean it has not been done.... Should be an easy fit though...
    Dave
