Replaced battery , what now? | FerrariChat
Discussion in '360/430' started by nnjferrari, May 20, 2015.
  1. nnjferrari
    nnjferrari Karting
    Oct 11, 2014
    103
    north new jersey
    matthew
    I replaced my dead battery, do I need to do anything else with the car before use? Anything to reset or set?
  2. Chrisnlbc
    Chrisnlbc Formula Junior
    Jan 9, 2015
    374
    Huntington Beach
    Let it idle for 10 mins or so for it to reset the parameters on the first start. Then go drive her and enjoy!
  3. Skidkid
    Skidkid F1 Veteran
    9,523
    Campbell, CA
    John Zornes
    The start sequence is in the manual but as I recall, you turn to key on, let it sit for something like 30 seconds, start the car and let idle (can't remember the time). DO NOT touch any controls or gas pedal after you start the car.
  4. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    #4 netman, May 21, 2015
  5. Skidkid
    Skidkid F1 Veteran
    9,523
    Campbell, CA
    John Zornes
    Those are the drive cycle not the reset startup sequence. Different things but he will need your procedure too in order to set the monitors.
  6. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    I was told it was the same process as the first procedure in the process I offered is to turn off the battery. The third attachment is technical service bulletin from Ferrari.
  7. delaney
    delaney Formula Junior
    Nov 8, 2003
    720
    Montgomery TX
    PETER DELANEY
    Turn the key to start the car. Don't touch the accelerator at all. It'll run rough for a minute or so until the car parameters are reset. Once it's running smoothly you're done.
  8. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Wait 10 seconds with the ignition on before starting the engine - this is to let the motorised parts of the car learn their positions.
    Once the engine is started, the engine may run rough for a little while whilst the adaptive parameters (fuel trims) are re-learnt.
