Replaced slave cylinder, but now clutch slipping? | FerrariChat
Discussion in '348/355' started by Jpwulf, Oct 15, 2024.
  1. Jpwulf
    Jpwulf Karting
    Sep 26, 2022
    79
    Oregon
    John Wulf
    Replaced the slave cylinder, as my old one broke at the seam and had full fluid loss. Installed the new HE kit and triple seals, put it all back together, and went for my first drive.
    Right away I noticed some rattle noise from the back of the car when driving up my driveway, and thought it was the bypass valve, but realized over time it was coming from the clutch housing. As soon as I got on the main road, if I put any amount of gas to accelerate, the clutch would slip and the RPM’s would rise. It seemed to do fine just casually driving, but if I tried to give anything more, it would slip.
    The clutch was fine before all this happened. Just curious if anyone had ideas on what could cause this? Maybe some of the fluid got into the clutch when the slave cylinder burst? But it didn’t look like it did when we removed it? Help?
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    Did you measure the clutch plate thickness?
    Did you repack the flywheel with new grease?
  3. Jpwulf
    Jpwulf Karting
    Sep 26, 2022
    79
    Oregon
    John Wulf
    We never touched the clutch outside of removing it to access the slave cylinder
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,923
    Central NJ
    Dominick
    Def sounds like fluid on clutch - just a SWAG
  5. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    There are accompanying o rings as well. Also depending on the car year the base flange needs to be swapped. Also it does happen that you can fold the seal lip when installing ensuring leaks. Either way, it all comes off for inspection. My guess would be error in process. It can be easy to get wrong, tricky to get right.
    flash32 likes this.
  6. Jpwulf
    Jpwulf Karting
    Sep 26, 2022
    79
    Oregon
    John Wulf
    Thanks all for the replies. I’ll take it back apart and see if there is anything obvious.
    flash32 likes this.
  7. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,895
    Richmond
    Pete
    I had this exact same problem - bearing in the old slave wears and allows a worn clutch to still grab, new bearing doesn't have as much play so it will no longer grab. Measure the thickness of your clutch disk, my bet is it's past acceptable wear limits. Ferrari don't let the clutch wear down to the rivets and gouge the flywheel, it starts slipping well before that.
    See here: https://www.ferrarichat.com/forum/threads/new-t-o-bearing-now-clutch-is-slipping.348223/
    Jpwulf likes this.
  8. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    People say don’t fix it if it ain’t broke, but the cars are 30 years old. When I pulled the pumpkin for tob I stuck in an entire new AP clutch assembly and new flywheel and repacked the voith. If I had a nickel for every thread of people resurfacing or replacing JUST clutch plates only to have another issue, well I’d have a lot of nickels.
    Jpwulf likes this.
  9. Jpwulf
    Jpwulf Karting
    Sep 26, 2022
    79
    Oregon
    John Wulf
    Thank you all! Wise advise as always!
