Replacement 308 window switches | FerrariChat
Discussion in 'Technical Q&A' started by rolindsay, Aug 2, 2006.
  1. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    + Has anyone found an aftermarket replacement for the 308 window
    switches? Something with similar mounting geometry? The current
    carrying capacity is not much of an issue as I plan to control the window
    motors with contactors (relays).
    + How much current does a moderately healthy window motor draw?
    If I run heavy gauge hot lines to the doors, I need to fuse them over
    at the fuse panel(s). Even if I can't get that info in advance, I can
    just measure the current drawn by my motors and fuse accordingly.
    + Anyone have a scan, JPG or PDF format perhaps, of the early 308GTB's
    electrical system? I would appreciate a copy. Thanks.
    -rick
  2. Dr Tommy Cosgrove
    36,593
    Birmingham, AL
    Tommy
    what year? do you have a carbed 308 with the switches on the door?
  3. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    Yes sir, Dr. Tommy.
    I have a '79 308GTB fully Euro car.
    Rick / Houston
  4. 308ROB
    308ROB Formula Junior
    884
    Netherlands
    Rob
    Rick,
    Try www.international-auto.com and click on electrical and click on power window switches .looks the same as alfa romeo spider.succesRob.
  5. 308ROB
    884
    Netherlands
    Rob
    Bay the way: Thanks to Dr. Tommy Cosgrove, he is the one who put this adress on F-Chat.Rob
  6. Dr Tommy Cosgrove
    36,593
    Birmingham, AL
    Tommy
    Actually those are different than the carbed cars. I have a couple of those older switches. I have no use for them so you can have them if you want. I'll did around for them tonight.
