360 - Replacement alternator | FerrariChat
360 Replacement alternator
Discussion in '360/430' started by 78bonanza, Nov 14, 2020.
  1. 78bonanza
    78bonanza Formula Junior
    Apr 1, 2018
    350
    Jim Cear
    Seems like the bearing on my alternator is going . Is there a recommendation to source a replacement ? I see Scuderia has them for about $700.
  2. hessank
    hessank Formula 3
    1,938
    Canada, Florida
    Fred
    ....... and don't throw the old one away. It can easily be rebuilt and kept as a spare
  3. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    FWIW, the only time my car stranded me was when a rebuilt alternator failed.
    APA#1 likes this.
  4. rizzo308
    rizzo308 F1 Rookie
    2,784
    Perth, Australia
    riggio
    For future reference guys, this model will work Toyota land cruiser they are identical. I stripped it cleaned slatted on new regulator had my sparky bench test it, gud to go.
    Has not missed a beat.
    Cheers
  5. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner
    Jan 19, 2004
    7,864
    San Jose, California
    I noticed that too when researching a rebuilt alternator (Toyota compatibility).
    Need4Spd likes this.
  6. hessank
    hessank Formula 3
    1,938
    Canada, Florida
    Fred
    The parts that wear out to cause an alternator to fail are all replaceable.
    Over the past 40 years I have used several rebuilt alternators (I always rebuild mine vs getting an Asian core instead)
    If a rebuilt fails its prop because of the person who put it back together.
  7. kaj750
    kaj750 Formula Junior
    May 9, 2022
    302
    Fresno, CA
    Bumping this thread after finding via Google search. Can anybody confirm any Land cruiser alternators that will work? I was unable to find one with a pulley that is compatible with our alternator belt.
  8. kaj750
    May 9, 2022
    302
    Fresno, CA
    Land cruiser alternator has the wrong upper mount. Not sure how the guy above made it work.
  9. rizzo308
    rizzo308 F1 Rookie
    2,784
    Perth, Australia
    riggio
    That's the alt i used the only mod i had to make was to drill out the hole for the adjustable slide that toyota uses as 360 adjuster is threaded rod type. I replaced the bearings and rectifier. No issues up to date.
    Cheers
