Hopefully you're not the moron I am...I'm on my 2nd 328, but don't drive it much, took to my mechanic recently, because the antenna wasn't going up or down when I turned on/off the radio. Luckily, I also was having new tires put on, They called to say the tires were on and the antenna worked fine for them....Went to pick it up, and damn antenna wasn't working again, until the mechanic came out to show me the separate button that I TOTALLY forgot about. They all got a good laugh at my expense
Not 100% sure as for US cars, but most, if not all, "euro" 328s have Bosch "Autojet II" antennas. Both my '89 (GTB & GTS) have one. Rgds Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Try Ferr parts in Sacramento, I have had great luck using them to find me new and good used OEM parts for my 89. https://www.ebay.com/itm/225545134265?hash=item348389a0b9:g:K4cAAOSwETdkQu4h&amdata=enc%3AAQAIAAAA4DRQDDSV9rd%2B8QbjQvuAAuMp4q%2BNJAi8mnBG6J%2FM5k%2BbEFOBWloLzTRhtrS4rlbTduqhrFGo0ykhPBTS3VgdhwKcD1rEKecdTVSXh2spEH88GmY%2FBkgQNpU9ONQfnI57E9ZvcE6KhLnGo1SRgpJyI9xAZn1Ocd1drSENnpKceXO4XWVsZPVegE1rjuYwo9A2e20wUbxy5PS1tq1G%2BRpugXhCpPsiJ64dW%2FAwwaiK%2BniEK366yY%2BHjF41wu63odbGrnm8L2GYP3WwN3oGDP4gp2c1evBk8NMnHmZL6YYZQEvL%7Ctkp%3ABFBMrojK-Z9i 916 974 1939 G
Thought I'd update this thread. Just replaced my original semi automatic antenna with this Metra unit 44-PW22: http://metraonline.com/part/Aftermarket_Antenna_44-PW22 I bought through Amazon for the free shipping. Image Unavailable, Please Login I wanted to maintain the functionality of the original manual switch. There is a thread in the tech section that shows how to convert a fully automatic antenna to semi automatic using diodes across the leads from the antenna switch: https://www.ferrarichat.com/forum/threads/early-semi-auto-antenna-question.3390/page-2 I didn't put the diode across the switch terminals, just straddled the leads in the boot. Image Unavailable, Please Login Antenna works great with the existing switch to raise and lower the antenna.
