News
replacement battery for a 360
Discussion in '360/430' started by 720, Jul 28, 2004.
  1. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    So. Cal and No. Utah
    Rick
    sorry if this subject has already been discussed, but i tried searching and didn't find what i was looking for.
    has anybody found a better battery to replace the stock 360 battery when it dies? i've heard good things about optima batteries, but i don't think they make one that fits in the 360 battery area??
  2. SrfCity
    SrfCity F1 Veteran
    Nov 1, 2003
    9,842
    Orange County, CA
    I noticed mine has an Interstate battery in it. Not sure what model but it fits perfectly. Works great especially when I hook up the o'l battery tender.
  3. f355spider
    f355spider F1 World Champ
    Rossa Subscribed Owner
    May 29, 2001
    17,058
    Hugh G. Rection
    Most of the FNA dealers are recommending a Interstate brand battery...not sure of the size either...but sounds like the way to go. As you surmise, several have tried to fit an Optima, but apparently it is a "no go".
  4. Scotty
    Scotty F1 Veteran
    6,334
    Oregon
    Scotty Ferrari
    I replaced mine with an Interstate (again, not perfectly sure of the model--I had the local Ferrari dealer order it for me). At least one person on this board installed an Optima, but when I carefully measured the available Optima sizes, this seemed like anything but a bolt in installation.
  5. tubeguy
    tubeguy Formula 3
    May 21, 2003
    1,036
    Upland California
    Kevin Deal
    Hey Rick!
    Fun looking at the cars...what a deal....
    The Optima will fit if you space up the top bracket...I did not do it, but someone else here did. You can go to their website and get sizes and post positions. I did all that work, then went stock as I was under warranty for it...
  6. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    Rick
    hi kevin,
    right now i'm not having any battery problems. i'm just looking for a better battery when mine crap out...which i've heard tends to happen sooner than later in the 360. LOL. i've heard a lot of good things about the optima so it would be interesting to see what it would take to get one to fit :) can you ask the person you know who did it what they had to do to make it work? thanks!
  7. tubeguy
    tubeguy Formula 3
    May 21, 2003
    1,036
    Upland California
    Kevin Deal
    What I was told is the rods that stick up does into a top plate held down with bolts. The rods must be longer. This is done by a long nut with the stud at the other end.
    I didn't do it though! This is second hand. I looked and it made sense.
  8. racerdj
    racerdj F1 Veteran
    Silver Subscribed Owner
    Jan 19, 2003
    6,645
    Indianapolis
    DJS
    My Diablo's OEM battery was replaced with an Interstate. It's the way I'll go with the 360.
  9. 4i2fly
    4i2fly Formula 3
    Apr 16, 2004
    1,330
    SF, Bay Area
    Dealer doesn't recommend the optima battery for the 360s bacause of what Tube Guy just explained. If it comes loose, man what a disaster down there and you will not see it until it goes dead...
