Replacement brake calipers | FerrariChat
Discussion in '308/328' started by Austin Newman, Jan 15, 2022.
  1. Austin Newman
    Austin Newman Karting
    Dec 18, 2019
    229
    Memphis
    Austin Newman
    SAFE4NOW likes this.
  2. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
    Not sure about the company, but I can tell you the fronts are the same as a 911 and the rears are 914.
  3. Steve Magnusson
    BANNED Lifetime Rossa
    26,822
    Many reports here of excellent results from PMB doing caliper rebuilds and at good price (you couldn't do it yourself for less because they do the replating, refresh the Welch plugs, etc.).
  4. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,149
    SanFrancisco BayArea
    1983 US 308 GTS QV
  5. Austin Newman
    Dec 18, 2019
    229
    Memphis
    Austin Newman
  6. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,149
    1983 US 308 GTS QV
    Most of us do it the opposite way; send our existing calipers to be rebuilt.
    Austin Newman likes this.
  7. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
  8. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Another happy F-chatter here. I sent mine in and they came back looking new. My only complaint is that although they re-zinc plated the calipers, they wouldn't re-plate the pad hardware - pins and springs/clips. It was spray painted and this didn't do it for me. I had my bits re-plated with my next batch of hardware.
  9. Austin Newman
    Dec 18, 2019
    229
    Memphis
    Austin Newman
    Now i know this isn’t a fair comparison…. But what are peoples thoughts on doing this vs getting a BBK upgrade?? … assuming money wasn’t an issue.. is that a desirable thing to see on a car when buying?
  10. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    Any particular years, or are they all the same?
    Doug
  11. Rifledriver
    37,103
    Is it a specific kit you are speaking of? On a 308 the rear calipers are the hand brakes. That becomes very problematic when replacing the brakes. Also 308s have never really had the reputation of being under braked like for instance a TR or an F40.
    In general for long term value the market rewards cars that are left stock.
    My experience with PMB has not been universally good.
  12. Rifledriver
    37,103
    The rears are 914 with a different sized space between the caliper halves. 914 has a different rotor thickness.
    Jonny Law likes this.
  13. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    Yup, the 308 rear calipers are shared with not just any ordinary 914-6 (which is rare enough), but only with the 914-6 GT version. The 914-6 had solid rear rotors, the 914-6 GT had wider vented rotors, like the 308.
    PMB's price to rebuild a pair of 308 rear calipers is $349.
    Around 8 years ago, PMB had a clearance sale on alloy rear 914-6 GT calipers, they are a couple of pounds lighter (each) than the regular calipers and were $900/pair, I bought a set then to replace my leaking original rear calipers. They have a reproduction set available again now, the 914/6 GT vented or 308 rear calipers are $1,695 per pair.
    PMB Performance Porsche 914-6 or 914-6/GT Reproduction Rear Caliper Set with Dual Bleeders
    Cheers,
    Gordon
  14. wildcat326
    wildcat326 Formula 3
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    They rebuilt/restored my calipers beautifully when I decided to go full Concours with my suspension. HIGHLY recommend.
  15. Austin Newman
    Dec 18, 2019
    229
    Memphis
    Austin Newman
    What else do you do with the suspension?
  16. Austin Newman
    Dec 18, 2019
    229
    Memphis
    Austin Newman
    #16 Austin Newman, Jan 18, 2022
    Can someone help me here.. apparently with the rear calipers your supposed to remove something else other then the pads and pins? I took the bleeder valve out. Is it the ebrake springs? I heard something about some cover?
  17. Steve Magnusson
    26,822
    The pistons of the rear caliper have mechanical "screw" mechanisms for extending/retracting them -- you can't just push the pistons in. There are "covers" both on the outboard side and the inboard side that are removed to access the piston mechanism adjustment "screw". See these threads like these for reference:
    https://www.ferrarichat.com/forum/threads/dino-308-rear-caliper-rebuild-thread.304911
    https://www.ferrarichat.com/forum/threads/stuck-allen-screws-for-rear-calipers.118220/#post-136018467
    The hex internal drive feature of the inboard cover is often stripped out. A much better aftermarket part (with an external hex drive) is available.
    waymar likes this.
  18. wildcat326
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    New shocks and springs; powder coated sway bars, control arms and brake dust shields; replaced all sway bar and control arm bushings + ball joints; rebuilt calipers; new rotors and brake hoses; greased/replaced wheel bearings, deep cleaned and protective coated hubs and drop links, rebuilt steering rack with Felton bushing and upgraded tie rod ends.
  19. Andy 308GTB
    Andy 308GTB F1 Rookie
    Jun 2, 2004
    2,669
    Essex, UK
    Andy M
    Gohigh54 likes this.
  20. wildcat326
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    That pic was taken before everything got tightened down;)
    (You can actually see the drop link bushings aren’t seated).
  21. Andy 308GTB
    Jun 2, 2004
    2,669
    Essex, UK
    Andy M
    That makes sense!
  22. tables2012
    tables2012 Rookie
    Aug 8, 2012
    4
    Ypsilanti, Mich
    John Ottino
    Set my rear calipers to them they did a great job. turnaround time was great, no problem's.. Only thing was the new bleeder I didn't like. cleaned the old ones and reused them.
  23. miketuason
    Feb 24, 2006
    15,811
    Cerritos, CA.
  24. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    Another vote for PMB here. Excellent company with good service and tons of knowledge.
