replacement fans/blade removal | FerrariChat
Discussion in '206/246' started by gblue, Jun 16, 2008.
  1. gblue
    gblue Formula Junior
    Dec 26, 2005
    317
    Maui Hawaii
    Gregg Blue
    Aloha...one of my fans stopped working and I'm thinking of installing a lightweight plastic one for more efficient cooling.....any leads?
    Also.....how do you remove the fan blade from the shaft to make it easier to get the motor out?
    Mahalo from Maui
    gregg blue 206 t 00350
  2. champtc
    champtc Formula Junior
    Apr 18, 2004
    732
    greg- u will notice that the nuts are standard & that is because the fans are Lucas Fans. The fitted them on old Jag sedans etc. If you call Xk's unlimited they sell them & pretty cheap from what I recall. The shaft for the fan has a flat spot and there is a grub screw (look carefully) that holds the fan to the shaft against the flatted part. Good Luck..its not a tough job
  3. DinoDriver
    DinoDriver Formula Junior
    Mar 14, 2005
    537
    Leesburg, VA
    Bill Ebert
    Greg, not sure you can find plastic replacements for this application. The area is fairly small so you are somewhat restricted in size and mounting hardware. The original Lucas fans were quite capable and robust with either 3-blade (Dino) or 4-blade (308s and later) fans. Assuming the rest of the cooling system is okay (good water pump and clean, freely flowing radiator), you'll find them plenty adequate. They may have been used in Jag sedans as champc says, but the Jag sources I talked to said they are from the Jag XKE V-12s - - Lucas P/N 78497-R for both. That's what I bought at this URL in Feb https://www.xksunlimited.com/xks/merchant.ihtml?pid=11735&lastcatid=109&step=4https://www.xksunlimited.com/xks/merchant.ihtml?pid=11735&lastcatid=109&step=4
    and they were just like the originals except for paint. They come with a bright zinc (silver) finish . . . should be gray hammertone if you are into keeping it original.
    Hope this helps.
    Bill
  4. sranderson
    sranderson Formula Junior
    Nov 15, 2003
    286
    SRA
    Gregg,
    I got my motor and blade replacements from Welsh Ent. (740) 282-8649 They specialize in Jags.
    Steve
  5. DinoDriver
    Mar 14, 2005
    537
    Leesburg, VA
    Bill Ebert
    Gregg, definitely go with what your fellow 206 owners have found acceptable. The 246 fans I found may not fit on the 206.
    Bill
  6. gblue
    Dec 26, 2005
    317
    Maui Hawaii
    Gregg Blue
    ALOHA....THANX FOR ALL THE INFO.....MY MOTORS ARE HELD ON WITH A BASE WITH 4 BOLTS....
    TOOK OFF THE LOWER GRILL SCREEN, AND THE SET SCREWS THAT HOLD THE BLADES ARE FROZEN....THINK I'LL JUST DRILL THEM OUT, REMOVE /REPLACE OR FIX THE ONE BAD MOTOR AND PUT ON THE PLASTIC 308 BLADES I GOT FROM DENNIS MCCANN LAST YEAR. MY OTHER OPTION IS TO PUT A PLASTIC COOLING FAN RIGHT UP AGAINST THE RADIATOR.......
    GREGG
  7. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Greg- I replaced my stock Ferrari/Lucas fans with Toyota fans many years ago. I have the originals should I care to return to stock, but the capacity, current draw, and cooling are all superior with modern fans. Took a bit of minor fabrication, but the result cannot be seen, and the car runs cool.
    Jim S.
