News
replacement headers
Discussion in '348/355' started by TonyC355gts, Dec 17, 2015.
  1. TonyC355gts
    TonyC355gts Karting
    Aug 15, 2009
    160
    Metro, New York
    Tony C
    I purchased a used set of fabspeed headers, but I noticed there wasn't any gaskets or heat shields. Can I use the gaskets from my original headers or do they make replacements.
  3. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,376
    Charleston SC
    Randy..alluneedtokno
    Fabspeed sells header blankets or you can make your own.
  4. Culprit
    Culprit Formula Junior
    345
    Santa Ana, CA
    Ian
    Ceramic coating them is another option to keep the engine bay cool. I had mine coated in white which looked great and seemed to insulate quite well. I think the process cost somewhere around $600 for both sides.
  5. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,383
    Montreal
    Tony
    if you bought used set and did not come with the shield plates for AC/ Alt then it was problem from long ago before they made the plates.
    I just bought a new set and now they come fully complete with heat plates, gaskets and nuts.
    where did you find used set?
  6. To remove this ad click here.
  7. TonyC355gts
    TonyC355gts Karting
    Aug 15, 2009
    160
    Metro, New York
    Tony C
    Bought the set about 2 yrs ago from a fellow fchat member along with high flow cats and capristo 3. Getting major done this winter and will have these changed at that time.
  8. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,383
    Montreal
    Tony
    #7 Drock28, Dec 17, 2015
    oh ya I saw that set for sale in classifieds I guess it was you who got them.
    you can buy the gaskets, nuts and heat plates seperately from Fabspeed.
    my engine is out right now too.
    headers should arrive any day.
    I'm going against the grain and wil have them installed straight out of the box.
    I spoke with couple people who did the same with no heat issues whatsoever.
    as long as the AC/alt shields are on should be fine. plus I have challenge grill to vacuum out the heat.
  9. TonyC355gts
    TonyC355gts Karting
    Aug 15, 2009
    160
    Metro, New York
    Tony C
    Probably going to have the headers coated at swain tech and I will call fabspeed tomorrow for the gaskets and bolts.
  10. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,383
    Montreal
    Tony
    even if you coat them I would still buy the AC/Alt heat shield plates.
  11. To remove this ad click here.
  12. life@8500
    life@8500 Karting
    Feb 22, 2005
    216
    Milford,CT
    C Ryan Ramotar
    #10 life@8500, Dec 17, 2015
  13. 8500rpm
    8500rpm Formula Junior
    May 20, 2014
    533
    San Francisco Bay
    Chan
    +1 on buying the bits from Fabspeed. Even with ceramic coating, the engine bay will not exactly "stay cool". You want every passive heat shield you can get to keep sensitive parts away from heat.
  14. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,145
    chris
    really liking the white ceramic coating.....mmmmm.....maybe should redo mine.
  15. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,145
    chris
    +1 Definitely.....or fabricate your own....easy to do.
