Replacement of external mirror casing | FerrariChat
Discussion in '456/550/575' started by BJJ, Sep 8, 2014.
  1. BJJ
    BJJ Formula 3
    1,301
    Stupid I damaged my passenger side external mirror, parts of the casing broke out. I glued them back on (leaving for holidays the next day), but this does not look acceptable.
    I have bought a used complete mirror assembly (which includes the window triangle, the arm, the actual casing and all components therein) in the correct colour and now wonder, whether it is possible to replace the mirror casing only, leaving the arm as is. i.e. without removing it from the door (which would seem not exactly a swift job).
    I unscrewed the 3 torx screws in the bottom of the arm. The casing comes off the arm, but the electrical wires prevent removal. I have not disassembled anything at the door, but can see from the replacement parts that the connector in the door will not fit through the arm cavity. I can look behind the mirror glas and see connectors (heating and motors), but there is no chance to get hold to them.
    Is there any chance to remove the mirror from the casing/drive block therein without destroying any components? If so, it would be very straight forward to replace the casing, since then the wires could be removed from the old casing and fitted into the new one, followed by assembly of the casing to the arm and reassembly of the wires and mirror glas.
  2. BJJ
    BJJ Formula 3
    1,301
    I found out.
    Take a flat tool and carefully pry the mirror glass off the motor unit, best at the outmost end of the mirror glas. To the mirror glas a plastic element is jointed, which (reversably) clicks into a counterpart being part of the motor unit.
    Then the two contacts of the glas heater can be removed, whereafter the mirror glas can be put aside. Then the motor unit can be removed and the contacts be disconnected.
    Then remove the three screws holding the mirror casing to the arm and remove the casing from the arm, thereby pulling the wires out of the casing.
    Fitting is simply the reverse process, wherein refitting of the mirror glass is somewhat less sweat raising.
    Ich refuse to take responsibility for broken glasses, if this route is followed ;o))
  3. Konadog06
    Konadog06 Formula Junior
    Aug 22, 2007
    963
    Daytona Beach, Florida
    Bill
    Bernhardt, great work on the disassembly. If at all possible it would be nice to see a pic of the backside of the mirror glass to see how it pops in and out. That seems to be the critical part.
    Understanding your post, you were then able to exchange the mirror housing (or casing) without ever having to remove the door card or go inside the door.
    Again nice job and thanks for sharing.
    Bill
    FL
  4. BJJ
    BJJ Formula 3
    1,301
    Hi Bill,
    I will make fotos this weekend and post them next Monday.
    Exact, the (movable) casing is exchangable this way without a need to remove anything else in or at the door, since the mirror arm remains where it is and the electrical connectors are disconnected in the mirror casing.
    An additional advantage is, that in case of a spare part of wrong colour only the casing needs to be painted. For a painting job the glass and the motor unit need to be removed anyway.
    Cheers, Bernhard
  5. Konadog06
    Aug 22, 2007
    963
    Bill
    Bernhard, Thank You!
    That would be great. This would be a significant advantage to those who need to repair the glass or repaint the housing/casing versus going through the hoops of disassembling the door to access, and then the mirror assembly.
    Bill
    FL
  6. BJJ
    BJJ Formula 3
    1,301
    #6 BJJ, Sep 15, 2014
    So, here are the fotos in a step by step manner. Please disregard the awful provisional repair shown in the first foto, it happened just one day before start into the holidays.
    The only special tool you need is a T10 Torx bit for the screws in der mirror housing. All other is standard stuff.
    Be brave, when carefully prying off the mirror glas ;o)). Another issue are the heater contacts on the mirror. It might be advisable to fixedly hold the contact on the glas using a plier (with cloth) and then to carefully remove the connector, which sits rather strongly on the contact. Simply pulling off of the connector would presumably destroy the heating element by ripping off the contact.
    All other steps are rather easy. At the end, watch out not to make a scratch into the door. Do not forget to remove dead spiders and the like in the case.
    Fitting of the new mirror case is reverse, obviously. The glass snaps in easily.
  7. Konadog06
    Aug 22, 2007
    963
    Bill
    Bernhard, Thanks so much for your time and efforts on these pics and instructions. Nicely done.
    In my case there are a few stone nicks on a mirror housing that I would prefer not to live with. Did not like the idea of door disassembly just to fix these nicks without having a better reason to go in there. This looks to be a lot more simple.
    Thanks Again,
    Bill
    FL
  8. user2006
    user2006 Karting
    Jun 29, 2006
    119
    Can it be done in the same way at the 456?
  9. BJJ
    BJJ Formula 3
    1,301
    Sorry, but I do not know, whether this will work with a 456, but I would assume that it is quite the same. Maybe someone else knows for sure?
  10. bay
    bay Formula 3
    Mar 13, 2011
    1,280
    Belgium
    Bernard
    Bernhard, Thanks , always very interesting !
    Aerosurfer likes this.
  11. BJJ
    BJJ Formula 3
    1,301
    Bill & Bay, thanks for the kind words, I am happy and greatful to be able contribute to a community, where so much valuable technical information is provided openly by various users. Bay, I love those on-board track day videos on your homepage.
    bay likes this.
  12. BJJ
    BJJ Formula 3
    1,301
    Having had the replacement casing repainted due to dents, I yesterday refitted the mirror and took the time during the (patiently) work. It took 15 minutes "door to door" in my private workshop. Give additional 5 minutes in case of the disassembly (due to particular care when taking off the heater contacts), then the total time needed for replacement is just a bit above half an hour.
    The paint job was done by a local smart repair shop, very well done, costs 50.-- Euro.
  13. Konadog06
    Aug 22, 2007
    963
    Bill
    Reviving this very good thread that Bernhard did years back for removing or repairing the mirror casing as he called it. The reason, I finally started messing with this project and learned something that might save someone else broken glass in the process. A while back I picked up some spare mirrors to learn on, disassemble, have the housing painted, and replace mine which show a few stone nicks. Following the instructions above I found that the glass will break. However, if one makes sure that they are prying on the plastic portion affixed to the back of the mirror they will not likely have a problem. Picture shows what I describe. It is not easy to see this on the assembled mirror until you start leveraging the mirror by prying it for better vantage point. Once you can see in there you will know where to apply pressure upon the plastic portion.
    Bill
    FL
    theunissenguido likes this.
  14. ajyiii
    ajyiii Formula Junior
    324
    Chicago
    Andrew Y
    Question - when you did your mirror how did you get this off out? (pic 1 and 2) I need to change the mirror gaskets (pic 3) and I am not sure if I just need to pull the individual wires out of the connector (they dont want tot come out!) or if I am missing something.
  15. Konadog06
    Aug 22, 2007
    963
    Bill
    Andrew it’s been too long to remember accurately. While looking at your pictures removing the individual three wires from the plug looks to be the easiest solution. The way I would do it is put masking tape on the plug and write on it where each color wire goes. Note that the plug likely only goes in one way and be sure the right wires are back in the same positions relative to the plugs shape.
    Those wires are usually held in by a small metal tab on the metal contact accessed by the back side of the plug. By using a thin awl or dental type pointed tool, fold each retaining tab towards the wire and the wire should slip right out the back. To reinstall just pry back up the tab, push the wire back into the plug and it should clip into place.
    Bill
    FL
  16. ajyiii
    324
    Chicago
    Andrew Y
    Thanks for getting back to me, yeah I went ahead and ordered a whole set of terminal pin removal tools/keys.
