Replacement of rear O2 sensors | FerrariChat
Discussion in '360/430' started by Scott Elkington, Aug 4, 2012.
  1. Scott Elkington
    Jan 6, 2010
    6
    Parker, Colorado
    Scott Elkington
    How do you release the the plug in connection on the rear O2 sensor for a 2001 360?
    The connector has two red side pieces attached to a black connector and would appear to be the release. Before I get physical and break the connector, I thought I would ask the forum. The front O2 sensors were very easy to replace.
    Thanks in advance.
    Scott
  2. NickPetino
    NickPetino Karting
    Aug 29, 2011
    138
    Staten Island, NYC
    Nick Petino
    Theres a little clip that actually slides out a few millimeters to release the harness. Its not like a typical connector... you'll see a little piece of plastic that is colored differently that holds the two pieces together.. try not to break the piece because it pretty much holds the harness to the piece. I know this is kinda vague but ill try to get a picture to explain it better... gimme a little while
  3. Scott Elkington
    Jan 6, 2010
    6
    Parker, Colorado
    Scott Elkington
    Thanks. I will try again tomorrow. I know it has to be something simple. Hopefully your picture will help. Thanks again.
    Scott
  4. Scott Elkington
    Jan 6, 2010
    6
    Parker, Colorado
    Scott Elkington
    Call Ferrari of Denver yesterday and they told me to just pry the red cap with a screwdriver until it shifts roughly 1/4". That worked and the rear O2 Sensors have been replaced. Thanks for your help.
    Scott
