Replacement of Water Temp Gauge - 308 | FerrariChat
Discussion in '308/328' started by dpardyferrari, Jun 27, 2007.
  1. dpardyferrari
    dpardyferrari Karting
    Aug 7, 2002
    115
    Brunswick Maine
    Darrell Pardy
    Hi Folks:
    I have a faulty water temp gauge in my 1984 308GTSI that I need to replace. I thought I would also replace the lights in my dashboard at the same time. Any suggestions on how to get started with the disasembly? PS - I already have the gauge and lights.
  2. BigTex
    79,386
    Houston, Texas
    Bubba
    Check ash13's "clock" thread below I think there's a link, she means speedo....
    The screws for the instrument plate are behind the dash lights...
    Or is your temp gauge in the console?
  3. BigTex
    79,386
    Houston, Texas
    Bubba
    Use the 'search' feature for the upgraded dash light bulb numbers.......
  4. dpardyferrari
    Aug 7, 2002
    115
    Brunswick Maine
    Darrell Pardy
    Sorry..as soon as I posted this I saw the other threads. Thanks for the re-direct and sorry for the clutter - Darrell
  5. BigTex
    79,386
    Houston, Texas
    Bubba
    No worries....not the first time!
    As you see in my comments to ash13, watch the plate edges against the vinyl........
    Good Luck!!
  6. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    What is the motivation for replacing the water-temp gauge, and not the sending unit?
  7. dpardyferrari
    Aug 7, 2002
    115
    Brunswick Maine
    Darrell Pardy
    The temperature gauge has been acting up for a while now (needle showing higher or lower than actual temperatures) and I can usually fix it by tapping the gauge itself. So...I assumed it was not the sending unit. I am getting tired though of tapping the damn gauge.
    Have I mis-diagnosed the problem?
  8. Crallscars
    Crallscars F1 Rookie
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    your finger sounds like a valuable tool !
  9. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    If your finger fixes the gauge, every time, then nope- you got it. I was wondering if you took some actual temp readings somewhere and matched them to the gauge first...
  10. dpardyferrari
    Aug 7, 2002
    115
    Brunswick Maine
    Darrell Pardy
    Yep...done that as well. I will however see if the gauge has good clean contact points, but since I have virtually rebuilt this car I guess its time for this part to go.
  11. BigTex
    79,386
    Houston, Texas
    Bubba
    LOL!
    Yep the electronics are troublesome...good luck!
  12. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    BTW, I haven't done the research, but WHERE is the sensor for the gauge? Where else (besides the radiator) is a good reading possible, with say an infrared device?
  13. Badman
    Badman Formula 3
    Mar 4, 2007
    1,116
    Gotham City
    Bruce Wayne
    I usually see them in the thermostat housing, but have to admit I don't know for sure on the 308. There's an electrical connector at the bottom of the expansion tank, which may be it. But that would be a silly place to put it, IMHO.
    Do you have an infrared temp gun? If not, I can bring one on Sunday.
  14. Steve Magnusson
    26,842
    The 308 water temp sensor is mounted in the (cast metal) Y-crossover pipe that runs between the two cyl. heads (i.e., where the hot coolant comes "out" of the engine).
  15. PT 328
    PT 328 F1 Rookie
    4,008
    Mine was reading incorrectly as well. Prior to replacing the gauge I cleaned the contacts on the back and all was good. Try that first.
    Dan
