Replacement spark plug wires | FerrariChat
Discussion in '308/328' started by GaryvH, Aug 1, 2020.
  1. GaryvH
    GaryvH Rookie
    Dec 1, 2003
    16
    Pittsburgh
    Hi everyone,
    I have a 308 QV 1983 and one bank of cylinders is not firing so I'm going to change the plug wires. The caps were replaced a couple of years ago and it hasn't been driven much.
    I have read so many threads regarding which ones to use. Birdman likes the ACCEL 4040R, (price is right) some like the Kingbourne and Magnecor. Do I use 7mm vs 8mm? I'm looking for a "reasonable solution" that will be easy to install.
    Any help would be appreciated.
    Thanks, Gary
  2. BigTex
    79,386
    Houston, Texas
    Bubba
    It's not your wires, taking out an entire bank...
    Coil/condensor failure, broken set of points??
    7mm
    Saabguy and thorn like this.
  3. BigTex
    79,386
    Houston, Texas
    Bubba
    Dave Helms had a huge spool of the 7mm wire, at one time.
    In Colorado.
  4. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,150
    SanFrancisco BayArea
    1983 US 308 GTS QV
    7mm are needed only if you want to thread the new wire through the old red rubber sheaths. If you don’t care about that, 8mm is more common and has no impact on performance.
  5. BigTex
    79,386
    Houston, Texas
    Bubba
    Sure, I was just answering the OEM size....
  6. jlc308
    jlc308 Karting
    Jul 11, 2009
    121
    Irvine CA
    Good time to eliminate the plug extenders, see attachment
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,586
    San Carlos, CA
    Mitchell Le
    How you doing Joe?
  8. Vonbarron
    Vonbarron Formula 3
    2,262
    Westside Mofo
    S B
    Crank position sensor I’m voting for
  9. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,242
    CT
    John Kreskovsky
    Has a similar problem a couple of years ago. Turned out to be a bad rotor. Carbon track to ground. Cheap fix ($12). As for wires, if you making your own, Belden 7mm spiral wound works well.
  10. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,812
    Cerritos, CA.
    83 QV doesn’t have points and condenser, if one banks goes it’s usually either the Digiplex, coil, or the crank sensor for that bank.
  11. johnk...
    Jun 11, 2004
    11,242
    CT
    John Kreskovsky
    Saabguy likes this.
  12. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    California SF bay area
    Paul
    Loss of an entire bank could be a coil wire but blindly throwing parts at a problem is not the way to troubleshoot. Doing it that way you'll never even know what it was that caused it.
  13. jlc308
    jlc308 Karting
    Jul 11, 2009
    121
    Irvine CA
    Hi Mitchell, doing fine, enjoying the SoCal sunshine but can't go anywhere because of virus
  14. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Isn't it that 7mm wires fit in the distributor cap holes and 8mm wires you need trim to get them to go into the holes?
    BillyD likes this.
  15. Cuddy K
    Cuddy K Karting
    Oct 30, 2017
    181
    Ian Karr
    I just replaced my wires. 7mm kingsborne. Fit in the red sleeves...and the dizzy cap.
  16. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    it was a long time ago but I used Acell 4040r 8mm wires in my 308 and I dont recall having to trim the coating/outer cover to get them in. Maybe some lube, but not trimming.
  17. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    Also a long time ago but 8mm wires fit into the distributor cap on my 328GTS. They did not fit into the sleeves but my new wires are red.
    waymar likes this.
  18. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    I don’t recommend removing the spark plug extenders or the boot that seals around the spark plug hole. Lots of things can fall into the gap around the plug wires. Then you can’t get the spark plug wrench on the plug or if you can, dirt and other things can drop into the cylinder when you remove the plug. Also, you can purchase spark plug extenders that are 0 resistance (328 version) as I recall that will Eliminate the troublesome and resistive 308 extenders.7mm wires work fine.
  19. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Go with Magnecor, great wires, well made from what I see. I replaced a set of solid copper wires on my car, noticeable difference, solid copper messed with the ignition modules.
