Replacing 1981 308gtsi Timing Drive Seal | FerrariChat
Discussion in 'Technical Q&A' started by SonyJuve25, Jul 26, 2016.
  1. SonyJuve25
    SonyJuve25 Rookie
    Jul 21, 2016
    13
    #1 SonyJuve25, Jul 26, 2016
    All, I am looking for guidance and procedures to replace the seal behind the timing gear drive in my 81 308gtsi. The seal on my engine is behind the outer bearing. I got as far as taking off the drive gears and removing the snap ring from the bearing leaking oil. Attached is a picture of what I am looking at.
  2. SonyJuve25
    SonyJuve25 Rookie
    Jul 21, 2016
    13
    @tomberlin, that showed great detail for taking the seal out from behind the pulley. Is it the same for the drive gears? pull bearing out and seal same way? thank you.
  3. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    The seals leak because the front bearing is bad. This isn't a difficult job but you either need to get the special bearing puller or you can drill a hole in the bearing retainer and and put a self tapping screw in the retainer and pull out the bearing. I'm sure if you use the search function there are posts on how some have done this. There are 2 different bearings used and seals. The early cars and the later cars meaning the carb vs. the FI
  4. SonyJuve25
    SonyJuve25 Rookie
    Jul 21, 2016
    13
    I'm back on the road. Thanks for the help everyone. run through of what I did, I pulled the bearing out by breaking the cage and using a screw to pull it while heating the cover. Then took off snap ring in front of seal and with using a hook tool and screwdriver pulled the old seal out.
