replacing 308 GT4 Dino choke cable | FerrariChat
Discussion in '308/328' started by miahshodan, Nov 14, 2020.
  1. miahshodan
    miahshodan Karting
    Feb 25, 2016
    94
    West Jordan, UT
    The choke cable on my 75 is broken at the control. How do I get to it to fix it. I can see it through the whole for the ashtray. Do I get to it from below the car or remove the center console?
  2. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    You need to lift up the center console in order to get at the back of the lever where the cable is clamped. Why do you want to replace it? Many owners feel it is unnecessary and may promote imbalance of carbs.
    miahshodan likes this.
  3. Rolly
    Rolly Rookie
    May 6, 2004
    7
    Ontario, Canada
    I've had my 75 for 19 years and was taught never to use the choke. Turn on the ignition, let the fuel pump build pressure for 15 seconds or so...pump the pedal 3 o4 4 times and it starts. Usually every time....if not, repeat and it catches.
  4. SamN
    SamN Rookie
    Oct 27, 2015
    45
    modesto califorinia
    The car did you a favor. Do not bother to re connect it. Like others have commented, you are not supposed to use the choke. Look up Ian Tyrrell on you tube and his thoughts on Webber carbs and chokes. I just had my carbs rebuilt by Mike Pierce, put them on without attaching the choke cable. Rolly is exactly right on starting procedure. Image Unavailable, Please Login
    Kindest Regards,
    Sam
  5. miahshodan
    miahshodan Karting
    Feb 25, 2016
    94
    West Jordan, UT
    thanks all, The car starts fine, but idles at 3,000 rpm when warm, or dies when idling when cold. I was hoping having an operational choke would allow me to turn the idle down, but sounds like I just need to deal with the other carb issues.
