Replacing 308 Speedo Light Bulbs | FerrariChat
Discussion in '308/328' started by Impactco, Sep 5, 2006.
  1. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    I have successfully replaced the bulbs in the tach with Sylvania 3893 bulbs and bypassed the rheostat in a quest for more voltage to my panel lights. I have two Sylvania 2723 bulbs for the speedo but how do you get at these bulbs? It's not obvious like the tach. In the attached pic are the items with the arrows where these bulbs reside? I cannot pull or pry these off.
    Also, all four screws that hold the panel in were missing. Anyone know the part number or suitable replacement for these? They are not in my parts manual for the '85.
    Any help appreciated!
  2. jhsalah
    jhsalah Formula 3 Silver Subscribed
    Apr 10, 2006
    2,409
    Philadelphia, PA
    Jawad
    Just out of curiosity, were you able to replace the bulbs in the tach by going under the steering wheel or did you have to take out the dash/console...?
    Like many, all my gauges are super dim. Just wondering what it takes to get back there....
  3. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    Whole procedure is here:
    http://www.nwrfca.org/faq/dashlights.html
    It doesn't mention how to pull the speedo bulbs though!
  4. jhsalah
    Apr 10, 2006
    2,409
    Philadelphia, PA
    Jawad
  5. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,048
    Uh, just have a go at them....I can't remember (have done a couple cars over the years) but I think you twist...just don't force anything...no big deal. Git er done! :)
  6. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    Yep, you were right. I just had to pry them out with a screwdriver and that did the trick.
  7. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    I went out and drove the car tonight and the panel is easily twice as bright as it was. With this mod and Birdman's fuse blocks, the car is almost modern now as far as lighting goes!
  8. ClydeM
    ClydeM F1 World Champ Owner Rossa Subscribed
    Nov 4, 2003
    11,943
    Wayne, NJ
    Clyde E. McMurdy
    Rather than pry the warning lights out with a screwdriver as the FAQ suggests, you might want to use a tip from an earlier thread:
    Wrap dental floss around the warning light & pull it out that way. No damage to the console.
  9. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    It wasn't the 4 console warning lights that were the issue. The bulbs IN the speedo were the issue. Good tip though.
