replacing a 355 soft top? | FerrariChat
Discussion in 'Technical Q&A' started by van22, Oct 26, 2006.
  1. van22
    van22 Karting
    227
    Absecon Island, New Jersey
    VAN C
    anyone out there ever try to replace a top on a 355 spider or is this strictly a convertable shop job.thanks van
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    That depends on your skill level. Here is a pictorial of replacing an old Detroit muscle car's convertible top: http://www.moparmusclemagazine.com/howto/155_0310_replace_convertible_top/
    and here are the instructions for replacing a Mercedes SL convertible top: http://www.worlduph.com/mbtopinstall.htm
    A 348 top is perhaps somewhere in between the two, though I haven't done it. A 355 top is powered, so it will be harder than replacing the 348 top.
    The whole Ferrari 348 OEM convertible top (supports, shocks, hinges, etc.) is $16,000.
    The cloth cover, if purchased aftermarket, is only $900 to $950 if you know what you are doing. http://www.the348.com/tech/348.html#ConvertibleTop
    So if you know about the 348 Primer, then you can replace your 348 top yourself for less than a grand. If you just take it to a Ferrari dealership and opt for a full replacement, then parts alone are more than $16,000: http://www.eurospares.co.uk/partsListing.asp?M=1&Mo=559&A=2&B=30695&S=&ID4=1264934
    You're looking at $25,000 for the whole 355 top ( http://www.eurospares.co.uk/partsListing.asp?M=1&Mo=522&A=2&B=29227&S=&ID4=1204023) if you go OEM!
  3. van22
    van22 Karting
    227
    VAN C
    thanks for the reply, the top works perfectly but have a 1/8 inch hole in the top over the drivers side. i know i can get the top for under a 1k but was unsure if it was going to need some stiching to complete the job. have all the time in the world come dec. as soon as the first snow falls and salt hits the road it won't be back out till we get a good rain.
