Replacing Cam Covers - help please! | FerrariChat
Discussion in '348/355' started by dasadrew, May 6, 2007.
  1. dasadrew
    dasadrew Formula Junior
    Aug 1, 2004
    683
    Germany
    Drew H.
    Having been inspired by others, I want to freshen up my 348 cam covers with red wrinkle paint.
    Can anyone give me a few tips?
    What seals etc do I need? The gaskets on the covers themselves were replaced about two years ago? Do they need replacing each time covers are removed? Is it false economy NOT to change them?
    Any other seals or gaskets I should replace while I have the covers off. (I have no leaks).
    Any other things to look for, like stud threads which strip out or anything like that?
    Any tips on the best way to get them out (via wheel arches or from above etc.)
    Any help most appreciated.
    Thanks in advance
    Drew
  2. Nicksta
    Nicksta Formula Junior
    Sep 16, 2006
    535
    DC Ranch & NY, NY
    Nick Ingle
    My 355 is going in for its major shortly and I have red paint peeling off my cam covers. I want them refinished - but who should do this and are there any special issues I should pay attention to. Not to hi-jack the thread, but this seems to match the topic pretty well and hopefully 348 and 355 owners can both report their experiences.
  3. stevew
    stevew Formula 3
    Jun 9, 2002
    1,839
    uk
    Steve
    #3 stevew, May 6, 2007
  4. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    Very nice!! :):)
    I will repaint mine when I do the engine out major. :):)
  5. life@8500
    life@8500 Karting
    Feb 22, 2005
    228
    Milford,CT
    C Ryan Ramotar
    Steve I tried a few internet searches but could not find Frost's paints. Could you provide some info on how to get some of this stuff?
  6. dasadrew
    Aug 1, 2004
    683
    Germany
    Drew H.
    #6 dasadrew, May 7, 2007
    Thanks Steve - it was your covers which inspired me! ;-)
    I went to FART but I see they do the paint to special order. I'd previously picked up the black, 'cos someone a while back posted that red isn't available and you paint black then spray red. It was this dubious process which had put me off up to now. After googling "VHT Wrinkle" I found a "local" supplier in Germany.
    On the gasket subject, is it 49 or 54 which you mean?
    Did you use any special tricks or tools to get them off? The reason I ask is that my workshop is in France but the car is in a lock-up in Germany, so I'll have to take all tools necessary in my Lufthansa baggage.
    Cheers,
    Drew
  7. stevew
    stevew Formula 3
    Jun 9, 2002
    1,839
    uk
    Steve
    http://www.frost.co.uk/
  8. stevew
    stevew Formula 3
    Jun 9, 2002
    1,839
    uk
    Steve
    It is 49 & 54 that you will need and the same for the other side.Note that oneof the gaskets is different for the other side.
    You will also need 2 x item 44.
    No special tools or tricks, but I have the engine out at the moment so it was pretty straightforward.
  9. dasadrew
    Aug 1, 2004
    683
    Germany
    Drew H.
  10. dasadrew
    Aug 1, 2004
    683
    Germany
    Drew H.
    Dohh! Forgot the most important question!
    How many cans did you use for the two covers?
    Drew
  11. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    I have two identical gaskets............
  12. chrisx666
    chrisx666 Formula Junior
    Dec 6, 2004
    562
    YorkshireUK
    Chris B
    #12 chrisx666, May 7, 2007
    The gaskets for the main covers are the same, but the cam end cover gaskets are different.
    Remember to use a small dab of RTV sealant where the gasket meets the o-rings at the pulley end or it could leak big time. Don't use too much or it will spread when you torque down the cover and a bit of sealant could end up in the oil.
  13. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    Where do you get all these 3D sketches?
    They do not exist in my work shop manual.
    Would be nice to have, I imagine.
    //B//
  14. Jimbo49
    Jimbo49 Formula 3
    Aug 5, 2004
    1,889
    Geelong, Australia
    James
    When will that be, and will you be documenting the process?
  15. dasadrew
    Aug 1, 2004
    683
    Germany
    Drew H.
    Parts Manual. CD-ROM turns up on eBay every so often. I have one for the 348 GTB/GTS. pm me if you're interested.
  16. stevew
    stevew Formula 3
    Jun 9, 2002
    1,839
    uk
    Steve
    One can for both, although I would buy two, just in case.
  17. dasadrew
    Aug 1, 2004
    683
    Germany
    Drew H.
    top man ;)
