Replacing cam seal 2005 612 vs 2001 456m | FerrariChat
Discussion in '612/599' started by smggms, Jul 16, 2019.
  1. smggms
    smggms Formula Junior
    Apr 29, 2018
    252
    Matt Godwin
    Is it the same ? I read some where that 612 much easier,
    Do u need to remove the time belt to access the cam-seal?
  2. tazandjan
    38,038
    The F133E (575M) and F-133F (612) engines both have cam seals that can be replaced without having to remove the cams, unlike the 456s and 550. Mine were done when the cambelts were changed, so not sure about whether you need to remove the belts or not.
  3. smggms
    Apr 29, 2018
    252
    Matt Godwin
    major service January 2018 in Ferrari dealer .. .. they replaced can belt Cam seal ..
    Didn’t last a year, is that normal .. ?
    Can u replace the cam seal without taking off cam belt?
  4. tazandjan
    38,038
    No, it is not normal.
  5. smggms
    Apr 29, 2018
    252
    Matt Godwin
    Yes .. my 456 lasted longer
    So the belt need to be removed to access the cam seal?
    It’s major service .. I’m still negotiating with Sf dealer .. this was missed by their PPI
    They should fix the leak before offering the power train warranty.. I think that Ferrari guidelines..
  6. tazandjan
    38,038
    My techs made their own tool to fit the seals tightly. Sounds like it is pretty easy to foul it up.
  7. smggms
    Apr 29, 2018
    252
    Matt Godwin
    Is it that complicated need special tool? The Ferrari dealer don’t have that tool ?
  8. tazandjan
    38,038
    When you want to do something correctly the first time....
  9. smggms
    Apr 29, 2018
    252
    Matt Godwin
    Terry
    Can you replace the cam seal buy it self , with out removing
    The belt on 612 ?
  10. smggms
    Apr 29, 2018
    252
    Matt Godwin
  11. tazandjan
    38,038
    Affirmative, not sure because mine were changed when the belts were changed. Have to ask your tech.
  12. smggms
    Apr 29, 2018
    252
    Matt Godwin
