Replacing Dino Rad Fans with Lucas Part - help! | FerrariChat
Discussion in '206/246' started by Fezzaphil, Aug 29, 2006.
  1. Fezzaphil
    Fezzaphil Formula Junior
    Sep 14, 2004
    370
    Philip
    I'm going to replace both cooling fan motors and blades on my 246, in the grand scheme of things it'll be easier and safer than trying to repair them.
    However from searching on here I've found that there has been a discussion on using the Lucas fans from an MG B V8. Is this correct?????
    I also run an MGB and am used to having Lucas stuff (although mine has a Kenlow fan) but I just want the correct part number or equivilent if possible before ordering and fitting the one I think is correct.
    Can anybody advise please?
    Phil
  2. dm_n_stuff
    dm_n_stuff Four Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2003
    43,715
    26.806311,-81.755805
    Dave M.
    Phil.
    It's a Lucas part, I think I matched it to a Jag fan too.
    I'll pull mine out of the box this AM and get all the numbers for you.
    although, any good motor shop can probably rebuild them for you.
    Moss Motors is a good source for these, along with a couple other Brit car supply houses.
    Are you fixated on making sure the part is original? Superformance sells a set of fans for reasonable money that have four blade plastic fans (Like the 308 uses, I'm told) that worked great on my car. Significantly improves airflow, and the plastic blades reduce wear on the motors. Fit right in like the originals.
    I'll be back later this morning with more info on the lucas part #.
    Dave
  3. Fezzaphil
    Sep 14, 2004
    370
    Philip
    thanks Dave!
  4. gblue
    gblue Formula Junior
    Dec 26, 2005
    317
    Maui Hawaii
    Gregg Blue
    Aloha..my fan motors are fine....can I just change to the plastic blades to improve cooling?.........Gregg ...... 69 206 GT
  5. BigTex
    BigTex Seven Time F1 World Champ Owner Rossa Subscribed
    Dec 6, 2002
    79,368
    Houston, Texas
    Bubba
    If the same as 308, it's a Jag XKE v12 unit.
    I replaced one recently, it's in the parts thread in 308 section.....$142.
    I had it as a Lucas #78497, and updated with a C34368 @ WorldPAC Parts.
    It was identical in every way to the original...had to spray it with splatter paint to match the older one.....;)
  6. BigTex
    Dec 6, 2002
    79,368
    Houston, Texas
    Bubba
    Even the 1977 Boxer at FoH had the same fans....three of them, though.
  7. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    Keith Mitchell Wintraub
    Early Dinos had Lucas "tombstone" fans and then the later cars went to the round ones. Dennis McCann had both last time I checked (about 2 years ago).
    Cheers...Keith
  8. dm_n_stuff
    Dec 10, 2003
    43,715
    Dave M.
    YUP.
    That's the part!!!
  9. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Link:
    http://www.worldpac.com/
  10. BigTex
    Dec 6, 2002
    79,368
    Houston, Texas
    Bubba
    Sure enough the Jag shop wanted $250, so I went to some padners in the Mercedes/BMW/Audi/Porsche shop, to order it........
    They take pity on Ferrrari owners, and past it thru at cost......to get me going again.
    *big hug*
  11. thecarreaper
    thecarreaper F1 World Champ Silver Subscribed
    Sep 30, 2003
    18,057
    Savannah
    i have three of the fans in my parts pile. 2 i think are good, one i think is for parts. if you have not found what you are looking for i will sell all 3 for $250.00 + shipping.
    where in the south are you ?
    i will also add that you can use the later QV fan blades for better cooling on the early fans. :)
  12. racerboy9
    racerboy9 F1 Rookie Silver Subscribed
    Nov 3, 2003
    2,642
    XK'S Unlimited has the reintroduced 78497 motors which are slightly different from the original as the butt of the motor housing is a separate piece. They list them for $111 and have the mounting bracket as well. I bought one to check it out and though not correct for a concours car I was pleased with it. They have a pic on their site. This link might work: http://www.xks.com/jaguar/newAndHot/index.aspx
  13. Fezzaphil
    Sep 14, 2004
    370
    Philip
    I am in Da South of the UK and not the US!
    Thanks anyway - all help really appreicated!
    I am chasing Moss up over here who are a big supplier of Lucas bits and pieces
  14. BigTex
    Dec 6, 2002
    79,368
    Houston, Texas
    Bubba
    Sorry, we were giving USA sources, Lucas should litter the wrecking yards there....plentiful as pecans!
    Those were good numbers though, for me.....
  15. sulzeruk
    sulzeruk Karting
    Aug 8, 2006
    59
    Bonnybridge, U.K.
    Alasdair Cowan
    Hi Phil, you should be able to get them direct from Lucas or LSUK as they are called now I think, let me know how you get on, I am going to change them on the car here!
    Al Cowan
  16. gblue
    Dec 26, 2005
    317
    Maui Hawaii
    Gregg Blue
    Aloha...I just ordered 2 plastic 4 blade relacement fans for my 206 from Dennis McCann for $61 each.....my motors work fine...didn't ask him about motors....gregg
    http://allferrariparts.com/parts_list.php
