Replacing gas guage | FerrariChat
Replacing gas guage
Discussion in '308/328' started by jonesdds, Nov 29, 2009.
  1. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    SB,CA & Park City UT
    Jeff
    Did a lot of searching but really couldn't find specifics on removal and replacement. Best I could tell, a couple screws need to be removed from underneath and the center piece will come out if I read the post correctly. If that is correct, then is it obvious how to remove the guages? Probably will replace all the bulbs while I'm in there, where should those be sourced?
    Jeff
  2. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,168
    E ' ' '/ F
    Snike Fingersmith
  3. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    Thanks but I'm talking about the center piece that houses the three gauges, stereo and vents. I found a lot of threads on the panel removal you speak of but not much with this piece.
    Jeff
