Replacing oil pressure sending unit | FerrariChat
Discussion in 'Technical Q&A' started by RWDOMKR, May 16, 2005.
  1. RWDOMKR
    RWDOMKR Karting
    Aug 18, 2004
    97
    Stockton, CA USA
    RWDOMKR
    I'll be replacing the oil pressure sending unit on my '75 GT4 this evening....any hints or tricks to the r&r??
    Many thanks!!
    R
  2. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Unplug the sender from the harness. Pull the filter to get access to the housing. Rags to catch any outflow. Put a spanner on the exposed nut of the sender. Away you go.
    Very easy.
    Philip
  3. dinogt4guy
    dinogt4guy F1 Rookie
    Oct 31, 2004
    3,411
    Hewitt, Tx.
    Kurtis Fordice
    ....Looks easy. In plain sight. Removing filter easy enough. Getting a wrench on the hex. Not so easy. I've tryed using a crows foot. I think King Kong put my old one on. pma1010, spanner wrench? What kind? I need one of those to make it easyer. RWOMKR, If you get yours off easly, let me know what you did.
    Kurt
  4. Gianluca
    Gianluca Formula Junior
    May 6, 2003
    349
    Centreville, Virgini
    Gianluca Chegai
    On my 308 GTSi twice I ended up having to remove the whole oil filter housing assembly to replace the oil pressure sending unit because I could not get a wrench on it.
    Next time, I will add a small pipe nipple to bring the sending unit out a bit and make it easier to put a wrench on it.
  5. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    #5 308GTS, May 16, 2005
  6. RWDOMKR
    RWDOMKR Karting
    Aug 18, 2004
    97
    Stockton, CA USA
    RWDOMKR
    Yea, that's what I thought....whole unit's coming off - thanks to all!!
    R
  7. dinogt4guy
    Oct 31, 2004
    3,411
    Hewitt, Tx.
    Kurtis Fordice
    ...did you find a good deal on one? The dealer here wants $136 for the darn thing!
    Kurt
  8. RWDOMKR
    RWDOMKR Karting
    Aug 18, 2004
    97
    Stockton, CA USA
    RWDOMKR
    I don't know yet....I've got the thing installed, but haven't received the invoice from Partsource yet....left it out of the shipping box. I'll let you know as soon as I know...
    R
  9. 4returbo
    4returbo Karting
    Oct 14, 2003
    60
    Indiana
    Rick Oliver
    For what it's worth. I was able to get mine off with a rag and an channel lock adjustable pliers. Very easy.
  10. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I did the same thing, only I didnt use a rag. If its not working, unless you just want a pretty Ferrari part to put on a desk, if it gets destroyed removing it who cares? I used a channel lock as well, and in reality, it didnt hurt it at all, it unscrewed very easily. I did however, use oil rated teflon tape on it before screwing it back in.
  11. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Hey Paul
    FYI, my race fab guy indicated "we" (me) should stay away from teflon tape. He did recommend a Permatex thread sealer (white paste) for the pipe thread connections we used. This stuff has very specific application instructions (e.g., apply to 3/4 of thread bore and not to the first two threads...).
    Philip
