Replacing outer door trim, remove door panel? Pic included | FerrariChat
Discussion in '348/355' started by Redlyne_mr2, Jan 11, 2017.
  1. Redlyne_mr2
    Redlyne_mr2 Formula Junior
    Aug 5, 2009
    473
    Calgary, Alberta
    Ryan D
    #1 Redlyne_mr2, Jan 11, 2017
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Do you mean the very thin strip on the edge of the door panel? If so, no the door panel does not need to come off. But, that trim is tight so a little prying is needed.
  3. Redlyne_mr2
    Aug 5, 2009
    473
    Calgary, Alberta
    Ryan D
    Yup that rubber trim on the exterior of the door.
  4. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hey Ryan,
    I'm misunderstanding you. What rubber trim are you referring to? I was talking about a leather trim piece.
  5. Redlyne_mr2
    Aug 5, 2009
    473
    Calgary, Alberta
    Ryan D
    Check out the first pic. See on the exterior of the door? See near the door triangle? You can see the trim is cut. Looking to remove and replace that.
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Got it - I understand now. The inner mirror triangle needs to come off for sure as a seal in that area covers the trim you wish to replace.
    Personally, I would remove the door panel for much better access. It only takes 5-10 minutes to remove the door panel.
