430 - Replacing Passenger Door Light Switch F430 | FerrariChat
430 Replacing Passenger Door Light Switch F430
Discussion in '360/430' started by F1fletch, Apr 11, 2020.
  1. F1fletch
    F1fletch Rookie
    Nov 21, 2019
    43
    Pacifica
    Darren Fletcher
    Anyone done this? Drivers side works fine but passenger side doesn’t kick on the interior light switch...
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    Does the red light in the door edge come on as would thing its on same switch . Looks to be a simple change out from the drawings. Only £18 switch
  3. F1fletch
    F1fletch Rookie
    Nov 21, 2019
    43
    Pacifica
    Darren Fletcher
    No it doesn’t, I will get a new switch ;)
    Thank you!
  4. F1fletch
    F1fletch Rookie
    Nov 21, 2019
    43
    Pacifica
    Darren Fletcher
    #4 F1fletch, Apr 12, 2020
    Or not.....they are no longer available;(
    However, I did recheck and the red light does indeed come on but only the drivers door activates the interior dome light. Interesting...
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    Pt no 179697 Pillar switch shown as available in eurospares uk @£18. I am glad u dont do my shopping as i would starve.
  6. F1fletch
    F1fletch Rookie
    Nov 21, 2019
    43
    Pacifica
    Darren Fletcher
    Good to know, thank you. Now I just have to figure out why the red light comes on, as you said I am not sure it is on the same switch.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    When i close the door with me outside, the light goes out after 14 seconds on both doors, but if i open the door and then sit on the sill and press the switch in, nothing happens and the light stays on. Work that one out ? I also tried with me sitting in drivers seat ( bear in mind drivers seat on correct side here) but still stayed on.
    The door has a multi pin plug, i would be tempted to disconnect and spray with some contact cleaner in case its connected to door lock
