Replacing Radio/Clock in my 74 Dino | FerrariChat
Discussion in '206/246' started by MRONY, Apr 28, 2007.
  1. MRONY
    MRONY Formula Junior
    Mar 17, 2007
    707
    New York City
    Mike O.
    It still has the original Blaupunkt in it, which works, except for the tape player. I wouldn't mind putting in something modern, so I can plug my Zune (NOT iPod!) into it. Any opinions on whether this is a big deal to do myself? Or should I let a pro do it? Any recommendations on a good replacement?
    The only thing not working is the clock. Not that it really matters, but where would I ever find one to replace that if I get obesessed with it?
  2. dm_n_stuff
    Dec 10, 2003
    43,734
    26.806311,-81.755805
    Dave M.
    #2 dm_n_stuff, Apr 28, 2007
    Radio. You're never gonna get GREAT sound in the Dino. No place for great speakers, a big amp, etc. But, I'd think about getting the original fixed, or a nice period correct radio. There are guys out there who can modernize the guts of your radio, and make it whatever pod ready.
    You can probably do the radio if you really want. It's a standard din sized hole, you can swap for a newer full din sized replacement. I had a really nice mcIntosh in my car for a while. Looked good, worked well. Switched back to a becker.
    Clock. got mine fixed, swapped out newer guts for the original ones. Quartz innards from a newer clock behind the original face. Cost a couple hundred bucks and will run longer than replacing it with the same as the car came with, which will undoubtedly break again.
    DM
  3. bernardo66
    bernardo66 The Crazy Cat Man
    Dec 14, 2003
    26,527
    Montreal Canada
    Bernie
    Cute touch with the key fob. ;)
  4. dm_n_stuff
    Dec 10, 2003
    43,734
    Dave M.
    Gracias Senior.
    Dave (pictures speak a 1000 words) M.
  5. MRONY
    Mar 17, 2007
    707
    New York City
    Mike O.
    Thanks, and rally nice photos. The McIntosh piece is the best-looking car stero I've ever seen. I have one of their amps -- never knew the did cars.
    Not looking for the greatest sound, just something decent other than radio!
    I was actually surprised how "quiet" (it's all relative) the car is inside -- you can listen to music, even with the top off!
  6. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    I had an Alpine CD player installed in ours last year. It did require cutting the dash, but I think that can't be avoided if one wants to play CDs. I wanted to get a small amp and stick it up under that dash someplace, but it seems that nobody makes small amps anymore. My head unit doesn't have an external input, but most of the latest models do.
    I got a couple of Boston Acoustics speakers that are pretty efficient, they sound darn good for basic speakers and fit perfectly in the doors. I can get decent volume before distortion sets in.
    I hasten to add that I did not do the installation myself.
    I'd post some photos, but the ones I had were lost in a hard drive crash and the car's currently in the shop having the suspension rebuilt, plus a few other things.
    The clock is right twice a day. I finally disconnected it last year after realizing that it was still draining the battery. Hey, the Alpine has a clock built in.
    I know that some of the purists around here would have me burn in Dino hell for cutting the dash, but I'm not all that interested in the whole concours scene.
  7. dm_n_stuff
    Dec 10, 2003
    43,734
    Dave M.
    #7 dm_n_stuff, Apr 29, 2007
    The McIntosh fit without cutting a bigger hole, but cost $1000+ new. (I bought it used). If you dig around some you can find stuff that will fit.
    I found an amp that was small enough to fit in the glove box. don't recall where, maybe from Crutchfield?
    DM
  8. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    A glovebox-sized amp would be perfect. I should give Crutchfield a call. I've bought tons of home and car gear from them over the years. I had a small Alpine amp in a Mazda I used to own. I wish now that I'd kept it (the amp, not the car). When I got the new Alpine about a year ago, the smallest amp the shop offered had a footprint about the size of a mouse pad. Some were huge! The trunk's out as a place to put it, too darned hot in there.
    Interesting that you were able to fit a CD player w/o cutting the dash. I always figured that to be impossible since a CD looks bigger in diameter than the standard "between the shafts" opening in an old style radio dash configuration, but maybe not... I'm curious as to how Mac pulled it off. I never even knew that they made car stereos.
  9. MRONY
    Mar 17, 2007
    707
    New York City
    Mike O.
    I was just checking out the Blaupunkt and noticed a "Record" button on it. Never seen one of those. Yhen the book sai it could record radio shows, or evenuse a microphone. I open up the glove compartment, and -- there's a 1970's vintage mic with a clip to mount it to the rear-view mirror, wired through to the back of the radio!
    I guess the doctor who owned the car originally must have wanted to record case notes or sing karioke!!
  10. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    I remember those. I think Pioneer and a few other mfrs. also made them. Although it's probably not real useful, it's quirky enough to be worth keeping.
  11. dm_n_stuff
    Dec 10, 2003
    43,734
    Dave M.
    Might serve as an input for MP3 or other player? Wonder if you could hear yourself as you recorded.
    hmmmm.......
  12. MRONY
    Mar 17, 2007
    707
    New York City
    Mike O.
    into the mic, it'd cause an EMP that would kill every piece of mechanical equipment on the east coast -- it's that bad.
    If I take it out, I'll save it, tho.
  13. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Alpine 9875
    http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16991
    Just plug the IPOD (I believe the Zune has the same connector, right?) into this Alpine headunit and stow the IPOD in the glovebox as the Alpine display fully replicates the IPOD display. It even charges the IPOD for you.
    Mounting is very easy; both the case mounting sleeve and the wire bundle fully remove (quick disconnect) so you can intall them without the head unit. All wiring is very well marked.
  14. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Re-originals has them
    https://www.reoriginals.com/index.asp?PageAction=VIEWCATS&Category=7608
    Would you consider a quartz movement in your old casing, using your face plate and hands for one-tenth of that price?
  15. MRONY
    Mar 17, 2007
    707
    New York City
    Mike O.
    I'd be happy either way. Just have to find out how to replace the movement on the original.
  16. tx246
    tx246 F1 Veteran
    6,663
    Texas
    Shawn
    DON'T put in a quartz clock, that is a very good indicator of "less-expensive" replacement. either do what dave did and have the guts changed to quartz and the face stay the same or have the clock rebuilt.
    all of dino's have clcoks that seem to work when they want to. sure if i kill the battery, i expect them to die. i have never figured out why it work when i am driving it, but come back the next day and start the car to see it isn't on the right time although it's working. if it is electric, it should keep time, or is this one of those great ferrari mysteries?
    personally, i love wearing mechanical watches and hate quartz. i am used to adjusting time as needed when i don't wear a watch everyday. the clock, as long as it's spinning, it keeps me happy, regardless of time.
  17. dm_n_stuff
    Dec 10, 2003
    43,734
    Dave M.
    I started out planning to get mine repaired. When we took it apart, that just wasn't possible, so we went with replacement innards instead.
    Works fine, but does adjust with a pull instead of a push.
    However, according to my concours stuff, is not a deduction.
  18. MRONY
    Mar 17, 2007
    707
    New York City
    Mike O.
    Any rec's on where to get the innards and do the replacement?
  19. dm_n_stuff
    Dec 10, 2003
    43,734
    Dave M.
    www.ferraripartsexchange.com
    lyle tanner
    914-454-3240
    they did mine (well sent it out) and did a really nice job.
    Palo Alto Speedometer will do it too. Just google 'em.
    Dave
  20. MRONY
    Mar 17, 2007
    707
    New York City
    Mike O.
    Thanks. Working on it.
  21. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Before replacing the inner movement of your clock, you might consider an fixing it.
    I have taken three Dino clocks apart. Quite easy to do. The most difficult part is getting the plastic housing separated from the mechanical aspects. The chrome bezel is difficult to remove cleanly.
    If you get the movement out, simply place everything on a clean towel in front of you on a table, with a small watchmaker's slotted screwdriver (Radio Shack - a dollar three eighty). What usually happens (in all three of my cases) is that the main shaft of the clock jumps out of its bearing, which is nothing but an indent in a end-piece.
    Careful study of the movement will reveal how it works. Nothing magic. In that you are going to replace it anyway, it might be fun and efficient for you to tackle it.
    Jim S.
  22. MRONY
    Mar 17, 2007
    707
    New York City
    Mike O.
    That does sound like fun to take a shot at... I've fixed a couple of alarm clocks with similar-sounding problems! As soon as I get around to taking it out of the dash, I'll let you know what I fin...
