Replacing Rear Brake Pads-Need Advice | FerrariChat
Discussion in '206/246' started by DinoDriver, Apr 20, 2007.
  1. DinoDriver
    DinoDriver Formula Junior
    Mar 14, 2005
    537
    Leesburg, VA
    Bill Ebert
    I'm trying to replace the brake pads on the rear calipers. Brakes have been operating perfectly but the pads are worn past the limit. Rotors are fine. On both rear calipers I've gotten the outboard pad out -- no problem, just turned the small screw with an Allen wrench and the piston retracted very nicely and out came the pad. However, the inboard pads were very difficult to get out and now that they are out, I can't push the inboard piston in on either caliper. I have disconnected the emergency brake cable from the caliper on both sides.
    Any suggestions or tricks I need to now to retract those inboard pistons?
    Bill
  2. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Use the proper brake pad-spreader clamp or
    crack the bleed screw to relieve pressure, then bleed the brakes.
  3. John Corbani
    John Corbani Formula 3
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    Remove aluminum plugs on back of calipers using an allen wrench. Use a smaller allen wrench on inner screw to retract pistons. Helps to have a pry bar help the pistons back in. Install pads. Pump brakes until pads touch then bleed brakes. Done. Don't have to loosen bleed screws to retract pistons. Somebody posted details and how to make new aluminum plugs after you have stripped the original hex. Best bet is to just use a hacksaw and put a screwdriver slot in them. Don't leave them off even though they are only dust covers.
  4. Steve Magnusson
    26,786
    #4 Steve Magnusson, Apr 20, 2007
    Here's a figure (246 is the same as 308 for this) showing the threaded dust cover that must be removed in order to access the female hex driven pinion gear that does the actual mechanical retraction of the inner pad as John mentioned (you can't just push the piston back in even if you open the line to let fluid out).
    IIRC, the material of the stock 308 dust cover plug is magnetic so it's not Aluminum (unless 246 are different), but it's not any stronger than Aluminum, so John's comments still apply well (high likelyhood it could already be damaged or be tough to get out without damaging/modifying). If you need new ones, try a Porsche aftermarket supplier (914 use the same type of rear caliper), and they have developed stainless steel ones with a 10mm external hex head drive to solve this problem (at reasonable cost ;)) -- 2nd jpeg is the aftermarket version from Performance Parts IIRC.
  5. DinoDriver
    Mar 14, 2005
    537
    Leesburg, VA
    Bill Ebert
    Hmm . . . so what John and 91tr are saying is that both the inboard and outboard caliper pistons have to be screwed back in. As I mentioned, the outboard were easy to access, but now I have to take out the embedded aluminum disc to access a hidden screw that then retracts the inboard. Geez, that's a pain in the butt! That's really bad engineering! I don't remember having to do that in the past except for the complete caliper rebuild I did about 5 years ago.
    Synchro, I tried to find a proper brake pad-spreader at the local NAPA shop. No luck. Only had the kind for modern single piston calipers. Were you successful with the "crack the bleeder" procedure?
    Thanks, Guys, for your suggestions. Maybe I'll take one of the calipers off and play with it . . . try to keep this as simple as possible.
    Bill
  6. DinoDriver
    Mar 14, 2005
    537
    Leesburg, VA
    Bill Ebert
    Okay, thanks to your pix, 91tr, I found the well hidden dust cover plug on the inboard side of the caliper (yes, it is damaged--stripped allen socket--but a small steel chisel loosened it) and I was able to retract both inboard pistons in the calipers. I'll finish up the job later today. I now remember the last time I did this--same hassle, same stripped allen socket, same chisel.
    Thanks again to all for the help. Another FChat assist!
    Bill
  7. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Bill - now that you have banged on the Allen screw on the inboard side of the caliper, you really did not have to do it.
    In theory (say no more) you should be able to remove the old pads without difficulty by pulling on the open end towards the rear, or tapping with a drift from the forward aspect. They should slide out with only minimal difficulty introduced by dust and rust.
    Gently but firmly spreading the pistons with a large screw driver or small curved-end bar should induce the pistons to retract to their pre-set position, which should allow room for the new pads to slide in (after cleaning the caliper shelves on which the new pads sit).
    What is being referred to as the "plug" provides access to the handbrake adjustment, which, if you have turned the inner Allen screw, will need to be readjusted. This adjustment simply moves the piston towards the rotor and acts as a stop, preventing the piston from retracting too much. There is only an adjustment on the inboard side. There is no adjustment on the outboard side. Once you get the new pads in, reconnect your handbrake. Engage the handle up and down a few times to seat the cable and mechanism. Dis-engage (release) the handbrake. Turn the wheel. It should not drag. Now turn the adjustment screw until the wheel no longer turns freely. Back out 1/4 or 1/2 turn. Retry the handbrake. Simply repeat this procedure until you feel that you have the wheel turning freely without the handbrake engaged, and that the handbrake lever does not have to be pulled to high to completely engage the brake.
    Have fun.
    Jim S.
  8. RGigante
    RGigante F1 Rookie
    Owner Project Master
    Nov 1, 2006
    2,874
    Portugal
    Would anyone know how to do the same thing on a 328 ?
    Thanks,
    Rui
  9. John Corbani
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    Sorry Jim. the above is not correct for my '72 GT and I don't think it is correct for any Ferrari or Porsche that uses the same calipers. There is no connection between the auto adjuster screw and the handbrake other than than they both control movement of the pads. You can not retract the pads more than about 0.01" without turning the inner screw. That will allow the pistons to move 1/4" if necesary. As soon as you put hydraulic pressure on the caliper the auto adjuster moves in and will not move back out. Same on both inner and outer halves of caliper. Hand brake is not affected when new pads are installed.
