Replacing Return Fuel Line | FerrariChat
Discussion in '348/355' started by Stackhouse, May 2, 2013.
  1. Stackhouse
    Stackhouse F1 Rookie
    Feb 14, 2004
    4,737
    IN YOUR TRUNK
    CT.. AKA Pimp Daddy
    For reference I have included this link from a previous thread showing the return lines connecting to the fuel tank.
    http://www.ferrarichat.com/forum/137616317-post9.html
    I would like to replace these lines with new lines and quick connectors. Can these be sourced via a local auto/industrial supplier?
    I assume these connectors , and possibly the line itself are no longer available, any suitable replacement or substitution available?
    Thanks in advance!
    CT
  2. Stackhouse
    Feb 14, 2004
    4,737
    IN YOUR TRUNK
    CT.. AKA Pimp Daddy
    #2 Stackhouse, May 2, 2013
    Here is a photo from the thread I linked for visual reference.
    To be clear I am looking for the black quick connect and attached fuel line you see being removed in this image.
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Good question.
    Those vapor recovery connectors should be able to be sourced from a fuel line supplier. I'm gonna have to pull that tank AGAIN and replace it, so I may end up needing those connectors. I haven't tried sourcing them because they didn't crack when I removed the tank the first time. If you find a supplier please let the rest of us know.
  4. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
  5. Stackhouse
    Feb 14, 2004
    4,737
    IN YOUR TRUNK
    CT.. AKA Pimp Daddy
    I will share my findings , the lead you provided is much appreciated. I will be calling them today.
    Cheers!
  6. AceMaster
    Feb 6, 2009
    34,786
    Ontario, Canada
    oh no - what happened this time?
  7. Stackhouse
    Feb 14, 2004
    4,737
    IN YOUR TRUNK
    CT.. AKA Pimp Daddy
    Contacted Ti they are a Bulk mfg and lead time is 4 weeks out. It appears that they can match the dimensions of the original quick connect however, it would be cheaper to purchase a complete return line system over a several hundred quick connects.
    I will follow up with dimensions and see what they can do , just for giggles...
    In the mean time if anyone knows of an off the shelf solution please chime in!
    This will be for a couple different Fcars, 355, Mondial T and 348, all seem to have identical connectors.
    Cheers
    CT
  8. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Count me in on this one - my vapor lines connectors need to be replaced.
  9. autowerks9
    autowerks9 Formula 3
    BANNED Rossa Subscribed
    Sep 1, 2009
    1,161
    North Wales, Pa.
    David S.
    If you can forward or post the connector dimensions. I will forward them to our shop foreman who makes our custom lines and see if he has a source.
    looks roughly 10-12mm od 6-8mm id and 30mm fron the stem to the retainer.
    David
  10. autowerks9
    Sep 1, 2009
    1,161
    North Wales, Pa.
    David S.
  11. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Same crap, but this time spot welds on the top popped out. I have a tank waiting to be installed, I'm just gonna wait to do it when I drop the engine for the major.
  12. fatbillybob
    Aug 10, 2002
    29,260
    socal
    you mean the vacuum collapse thing?
  13. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Yup.
  14. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    If someone can confirm a source we should put it in both the 348 and 355 DIY threads.
  15. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Ernie,
    Did you ever pull your tank? I'd like to know what size those connectors are on the vapor lines so I can order them while the car is garaged for the winter.
    Thanks.
    David
  16. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Nope, I haven't pulled it yet.
