Replacing RH Fuel Pump in 360 | FerrariChat
Discussion in 'Technical Q&A' started by Roadking80134, Jun 24, 2014.
  1. Roadking80134
    Roadking80134 Formula Junior
    Dec 5, 2013
    267
    Spring, TX
    Rick S
    I lost power (random misfire) in Cyl 1-4. Turns out it's the RH fuel pump - only putting out 5lb instead of 50ish. The service center says they can replace just the pump instead of the entire assembly. Research shows it's a Bosch 0 580 313 052. Anyone with a similar experience? Thoughts on replacing just the pump vs entire assembly?
    Thanks!
    Rick
  2. vrsurgeon
    vrsurgeon F1 World Champ
    16,543
    Charleston, SC
    Curt
    #2 vrsurgeon, Jun 24, 2014
    When mine had to be replaced it was because of plastic cracking. When you order the fuel pump.. you only have to order the pump itself, #1. Its a sealed single assembly with a filter and return line built into it. Unscrew the top #5, unbolt the 10mm bolts on #4, and then it just lifts out. You put the new one in and your good to go.
  3. Roadking80134
    Dec 5, 2013
    267
    Spring, TX
    Rick S
    Yeah, I'm inclined to replace the whole thing, vs opening the canister, replacing the bosch pump, and sealing it back up.
    Rick
