Replacing the Ferrari battery tender.... | FerrariChat
Discussion in '458 Italia/488/F8' started by Cylinderhead, Jun 4, 2022.
  1. Cylinderhead
    Cylinderhead Rookie
    Jan 13, 2007
    27
    San Rafael, CA
    Having just run over, and ruined, my Ferrari battery tender, I wonder if there's a way to replace it without bothering the Fcar parts department. Can the magnetic connector be spliced onto a "parts store" trickle charger?
    ShadowLAP likes this.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,947
    Central NJ
    Dominick
    The answer is yes .. but to be sure can you post a pic of the connector
    I believe that is the mag type disk which has two wires .. it always can be taken apart IIRC - two tiny screws in disk
  3. rob5819
    rob5819 Formula Junior
    Dec 12, 2017
    942
    San Diego
    Rob Barry
    cable https://www.cccharger.co.uk/product-page/ctek-ferrari-magnetic-connector
    battery tender https://www.amazon.com/CTEK-56-353-12-Volt-Battery-Charger/dp/B000FRLO9Y/ref=sr_1_3?crid=1493PJ7WXPU8W&keywords=ctek+7002+battery+charger&qid=1654354393&sprefix=ctek+7002,aps,160&sr=8-3
  4. Mrpseudonym
    Mrpseudonym Formula Junior
    602
    Sydney, Australia
    Best option is the CTEK MXS 5 or MXS 10. The original ferrari tender (which is as has been pointed out is just a rebadged CTEK) is rated under 5A so really not enough. As to the cable .. just google ‘cteck magnetic connector’ to find one closest to you.
    Cylinderhead and AD211 like this.
  5. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,790
    Weston, MA
    Paul
    I would also recommend the CTEK 7002.
    Need4Spd, 020147 and AD211 like this.
  6. Mrpseudonym
    602
    Sydney, Australia
    Yep that would be even better than the MXS 5
    Nospinzone likes this.
  7. 020147
    020147 F1 Rookie
    4,608
    Midwest
    My 7002 has been absolutely flawless on my 488! I got a new magnetic connector on eBay at the time, I believe the seller posts on the forum too.
    Nospinzone and rob5819 like this.
  8. up4speed
    up4speed F1 Rookie
    3,694
    Long Island, NY
    Chris
    I preferred the MXS5 over the 7002 when I bought mine. The reason being that it has an automatic winter mode that adjusts for temperature, without me needing to select the function.
