Replacing wiper blade rubber | FerrariChat
Discussion in '206/246' started by mar3kl, May 24, 2025.
  1. mar3kl
    mar3kl Formula Junior
    Nov 17, 2011
    470
    Silicon Valley
    Mark
    I was thinking about replacing the rubber on my Dino wiper blades. On my Mercedes of similar vintage it takes a couple of minutes - there’s a metal strip that holds the rubber in place. You slide the metal strip out, replace the rubber, and finally slide the strip back into place. The Dino Arman&c blades have a similar metal strip, but one end has a notch with one narrow clip so there’s no way I can see to slide the strip out. Am I missing something or is It just not designed for the rubber alone to be replaced?
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    The Arman blades were made to be totally changed and not replaceable like the Mercedes ones (which is a fabulous design BTW). When I restored mine I had to gently open them up and used rubber from a Bosch blade before closing them back up again. Super slow and time consuming and definitely not designed to be like that. The problem is that if you find some perfect NOS blades the rubbers will be dry rotted anyways. I think it is worth the effort to try and save the blades that you have.
  3. LittleEnzo
    LittleEnzo Karting
    Nov 10, 2024
    77
    FPS
  4. mar3kl
    Nov 17, 2011
    470
    Silicon Valley
    Mark
    Sounds like a fun weekend project. Thanks for the advice!
  5. npwmd2
    npwmd2 Formula Junior
    Mar 31, 2015
    254
    Hudson Valley
    Neal
    Try PIAA 94038 refill.
