REPORT: Low Voltage Relay For Starter Hot Soak Problem | FerrariChat
Discussion in 'Mondial' started by Rapalyea, Jun 16, 2015.
  1. Rapalyea
    Rapalyea Formula 3
    Jun 18, 2013
    1,511
    Georgia Mountains US
    David Rapalyea alias
    #1 Rapalyea, Jun 16, 2015
    Stunning improvement - kicks in the starter like a rail dragster. Talk about relieving "Exotic Car Syndrome". Oh what a relief it is! One caution though. The factory installed electrical connector that leads back to the ignition key is not an exact fit to the fitting that goes to the new low voltage relay; even though it might seem to be a good fit. First installation attempt left an open circuit.
    Did not exactly use a BMFH but you get the idea.
    PS: Even if your stock wiring works, reliably starts the car as mine has done for two years? It does not work like THIS. Like starting a 1965 Mustang. Very significant psychological boost for every run!
    PPS: The Amazon Price has more then doubled to more then $25 but is worth far far more.
    Bosch WR1 Starter Relay
  2. Alden
    Alden F1 Rookie
    3,627
    Central Florida
    Newbie question: Do I need this on my 1988 3.2?
    No problems so far but I am thinking probably so.
    Alden
  3. David Lind
    David Lind Formula 3
    Nov 19, 2008
    2,248
    David Lind
    Could we trouble you for a photo of the part and its installation, please?
    Thanks v much!
  4. Alden
    Alden F1 Rookie
    3,627
    Central Florida
  5. David Lind
    Nov 19, 2008
    2,248
    David Lind
  6. Alden
    Alden F1 Rookie
    3,627
    Central Florida
    Bumping this because I still need to know if I need it for my 1988 3.2 Cabriolet.
    Alden
  7. Ricambi America
    Sponsor Owner
    I had the same setup in my 348. It is Bosch WR1, and works like a champ.
  8. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
    Thanks for the great diagram!
    Regards,
    Jerry
  9. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
    Need? Probably not. But given the quality and durability of Ferrari electrics, why not? Certainly for peace of mind alone. Even at $25, that is like a rounding error at Starbucks!
    Regards,
    Jerry
  10. Rapalyea
    Rapalyea Formula 3
    Jun 18, 2013
    1,511
    I agree owners should consider this as routine upgrade maintenance. My 1986 has almost always started on the first turn of the key but almost always there was a brief interval till it engaged. This year it got 'hot soak' fever. I already had one of these relays on hand [about $12 when I bought it] and it simply eliminated every anxiety.
    We mounted it on one of the aluminum pieces that run up and down near the starter and ran the ground wire up and over a cross member and grounded it into an existing screw after scuffing the surface. Used some split plastic covering and a few cable ties.
    There was one problem. The fittings on the WR1 were not exactly a match for existing pieces even though they seemed tight. There was an open circuit the first time. I believe it was the lead that attached to the wire going to the key.
  11. David Lind
    Nov 19, 2008
    2,248
    David Lind
    Bosch WR 1 tarter Relay?
  12. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
    Yes, starter relay. Kit retails around $20-$25 last I checked. Sold by some online parts places like Pelican and Autohaus. Google is your friend
    Regards,
    Jerry
  13. Rapalyea
    Rapalyea Formula 3
    Jun 18, 2013
    1,511
    #13 Rapalyea, Sep 22, 2015
    Amazon
    Amazon.com: bosch wr1 starter relay
    PS: Bell did a nice custom job using a different relay and mounted it nicely in his upper engine bay. The wiring is not complicated as it might look on the schematic. Very very effective. You can work on upgrading the actual wiring, as my brother-in-law does on his Moto Guzzi motorcycle. But Italian wiring of this era makes Lucas look like NASA stuff.
  14. David Lind
    Nov 19, 2008
    2,248
    David Lind
    Thanks gentlemen!
