Reprogram Boxster S for More Power? | FerrariChat
Discussion in 'Porsche' started by PhilNotHill, Jun 2, 2015.
  1. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    2011 is out of warranty. No problems in the 4 years.
    Indy service is recommending updating the computer. 280 hp and 250 ft lbs of torque now. Reprogramming will mean hp up 35 hp and torque up 32' lbs.
    Anybody done this? Any problems? Is performance noticeable? How much?
  2. absent
    absent F1 Veteran
    Nov 2, 2003
    8,810
    illinois
    mark k.
    I have never seen a NA engine to get that kind of gain from simple ECU programming.
    Turbo or supercharged yes but NA will have negligent gain.
    Don't waste your money.
  3. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,594
    Gates Mills, Ohio
    Jon
    This, plus who knows what the side effects are.
    If Porsche couldn't figure it out...
  4. WPOZZZ
    WPOZZZ F1 Veteran
    Aug 22, 2012
    6,508
    Honolulu, HI
    That programmer must be smoking the good stuff.
  5. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    LOL I have been doing mods to Porsche's for 40 years, and all over the above is correct (though I cant comment on what they are smoking), TPC makes a turbo kit that will transform the car, but other than that even if you did go ECU, exhaust, and better airflow, you will probably not see much more than 15 or 20HP and that will likely be at the upper end of the RPM range.
  6. PhilNotHill
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    #6 PhilNotHill, Jun 3, 2015
    Thanks for the replies. Looks like the car is fast enough as is!
    The good stuff: Over $300 an ounce.
  7. GuyIncognito
    99,773
    I had an APR tune on a 997.1 Carrera S and there was more noticeable low end torque (I think it basically activates "sport mode" all the time) and a small difference in high end HP...all seat of the pants, never dyno'd it. no engine issues, at least over the 15k miles or so I drove it. no difference in mileage. I'd be surprised if their HP claims are true but the same can be said for most aftermarket exhaust companies too.
    that said, I don't know if I'd do it again, a lot of money for marginal gains.
