request for help - Testarossa brakes pressure | FerrariChat
Discussion in 'Boxers/TR/M' started by damusto, Sep 15, 2011.
  1. damusto
    damusto Karting
    Jul 27, 2011
    71
    Hello friends,
    I just held first ride in my Testarossa, and I have strong suspicion that brakes are far to weak !
    I checked the pads and discs obviously, they appear to be in good shape. So I would like to determine what should be brake fluid pressure in the system. Please help me, I gotta do something, because I almost crash last time.
    I live in Poland so I cant just go to mechanic - I'm sure he will see that car for first time.
    Whats worse I dont found this information in service book too.
    I hope someone know this, or would be able to check it, this way I will have good reference point, then I will be able to instruct my mechanics properly.
  2. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    #2 Mr.Chairman, Sep 15, 2011
    It could be a couple of things.. First I would check to see if any of the caliper pistons are seized. Pads and rotors may check out but if the pistons are seized your gonna have a problem. If that checks out I would check the booster and master cylinder for leaks or bad hoses leading to.. If that checks out I would check the vacuum assist pump located on the 7-12 bank in the engine bay. Check your hoses.. all of them.. bleed the system then take it from there.. Its a pretty simple set up.. My guess is going to be that you have some seized pistons.. I have had the vacuum assist pump shaft broken for a while and I only thing I felt was a stiffer pedal.. I also experienced seized calipers as well and it just feels like your stepping on a rock pedal.. Take your time and be thorough..
    R
  3. Testa-rossa
    Testa-rossa Karting
    Aug 21, 2010
    61
    The Netherlands
    Martijn
    testarossa is very "underbraked" Yes they feel crappy, they are crappy and I wonder why the hell they sold it with brakes that weak.....
  4. damusto
    damusto Karting
    Jul 27, 2011
    71
    #4 damusto, Sep 15, 2011
    Testa-rossa, its eastern europe - a bit different world.
    Now Mr.Chairman, thanks for the advice I would certainly do so.
    However, I left my car on a large sheet of paper, its some about 24h now.
    I will pump the brakes before depart. I think that is good rapid test for larger leaks, not necessarily from brake system(I know).
    Then I will go to the elevator, to watch the brakes carefully.
    Interestingly, no brake or abs light on dash. I wonder if this is not electronics ?
    I have experience with similar brakes(as driver) I mean 911(930) brakes often used in gr.2 and 4 race/rally cars like Ford Escort, or Fiat 131 Abarth. But these cars are much lighter ~880kg, there arent electronics and booster too.
    I wonder how to check my booster, I do not have a comparison like this should work.
    I havent been driving any Ferrari never before.
    Thats why I thought that the best way is to check max fluid pressure.
    I mean maybe its normal, I dont think taht brake pedal is to stiff in any way, clutch pedal is(more than I expected hehe)
    Maybe I need to change pads, for some more street useful, I mean optimum working temp.
    So 2 questions remain:
    - max (in system) brake fluid pressure
    - pads optimum operating temperature(seems to me these are the Galfers pads)
  5. Testa-rossa
    Testa-rossa Karting
    Aug 21, 2010
    61
    The Netherlands
    Martijn
    Yes, reading your story I guess you are......
  6. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,261
    Mel
    Hi Damusto,
    Could you please first introduce yourselve shortly and descibe the Testarossa (VIN, colour) ?
    A F car is a normal car; can you not go to a garage and put it on a break test bank ?
    These figures can then be compared to ... any other car ...
    But the breaks are a very weak point of the Testarossa ... until you upgrade to 512TR or Brembo...
    Please keep us informed about what actually caused the trouble ...
  7. Testa-rossa
    Testa-rossa Karting
    Aug 21, 2010
    61
    The Netherlands
    Martijn
    Ha Mel, again... 512 has got Brembo !!
  8. damusto
    damusto Karting
    Jul 27, 2011
    71
    Please dont take it as offense, but I prefer to remain anonymous.
    When it comes to me, I'm an architect by profession, amateur racing driver, and recently a head of small team working on computer driving simulation(a hobby for now but we have good results).
    The car is 1986 F110 AB/E, engine F113 B, in red, as far as I know there was no alteration.
    I need to ask what is break test bank, I dont understand this, thats language problem probably.
    And what is main difference between Testarossa and 512TR brakes ?
    At present moment, I detected only minor oil spills (nothing special)
    I hadnt much time on the elevator, so I will look on pistons at home this weekend
    Now I saw road test results, where the maximum braking force generated 0.95g so should not be so bad.
  9. Testa-rossa
    Testa-rossa Karting
    Aug 21, 2010
    61
    The Netherlands
    Martijn
    #9 Testa-rossa, Sep 15, 2011
    -Break test bank: testing equipment to measure braking force
    -512 TR has bigger aluminum Brembo brake calipers Brembo (logo only small not visible on the back of the caliper)
  10. damusto
    damusto Karting
    Jul 27, 2011
    71
    OK, thanks mate.
    If that is what I found, I need to go 298km to nearest workshop who has this device.
    Is a little risky, no risk no fun right ;-) any way I could check the fluid pressure on the spot at home. But I think I will have to choose.
  11. Testa-rossa
    Testa-rossa Karting
    Aug 21, 2010
    61
    The Netherlands
    Martijn
    Checking fluid pressure makes no sense... Why that question? It is odd. If a fly hits the pedal it gives less pressure than an elephant, so what do you want with that reading?
    X ponds on the pedal gives x pounds in the system, you cannot do anything with that number. Forget that part, it sounds silly..
    Just do a brake test on a bench, that'is wat you want to know. If you plan to track your car, drop the OEM brakes and put some MOVít or another brand -8pot calipers on because OEM will go into flames in a couple of rounds. I know because I track it too..
    Good luck!!
  12. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,290
    Maryland
    Curtis Campbell
    Robbie has the best approach here. Break the system down into its components and find the problem. If the car was not driven much and has been sitting for a while it is very likely that some of the pistons are frozen in the caliper. Rebuild kits are available for these calipers at reasonable cost (look at period BMW 5 Series parts - IIRC). They are ATE units.
    CC
  13. damusto
    damusto Karting
    Jul 27, 2011
    71
    #13 damusto, Sep 15, 2011
    I dont think its silly.
    And yes I expect 900-950 psi, when I will know this, I can calculate brake force easily.
    I know discs and wheels radius, I know pads area, I know how many pads are, and I know length of arm in which cylinders are operating.
    U know: pressure on surface = force, force on arm = torque, torque * friction coefficient and we know all.
    But more importantly, when I will know that the pressure should be X, and and I will have the same, I will know I dont need to look for any leak, then I will have to focus on brakes temperature.
    Yes I'm going to go to track sometimes, this will be autocross, and hillclimb, so thanks for the trick - I will think of better brakes of course.
    curtisc63 U are right, I will check all this this weekend as I wrote before.
    thx
  14. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    check your vacuum pump.
    rgds,
    Vincenzo
  15. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I disagree, if I hit my brake pedal hard my TR stands on it's nose. It requires light pressure under normal circumstances.
  16. Mr.Chairman
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    #16 Mr.Chairman, Sep 16, 2011
    Checking pressure makes no sense. Check the hardware first before you drive 250+ km to where you need to be.. You may be over thinking and I think your approach to this issue is somewhat backwards.. Good luck with your search and repairs.. I hope you get her back on the road quickly and safely.. Let us know what you find.
    R
  17. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    +1 :)
    P
  18. damusto
    damusto Karting
    Jul 27, 2011
    71
    Frankly I am very confused now.
    I called the diagnostic station which I found yesterday, They told me that of course they can investigate a braking force. But they told me also, that I should check the fluid pressure, and compare its value with the one from service manual in first place.
    In my workshop manual, I heve 14 pages about the brakes, and there is nothing about fluid pressure.
    Mr.Chairman I will check my hardware, but I have to act in advance too, U see Ferrari parts arent easy to get in Poland. I know a guy who can not fix his Pantera more than year for this reason. If I will touch the car, probably I will have to wait very long for it. I know the safety first, but U know I just bought this car and I wanted to enjoy a little.
    BTW
    This 1971 Pantera (stock car) I was driving it once, before owner exploded the engine, his brakes was a lot better. On the other hand I havent been driving aggressively.
    Some of You say the brakes are weak, other that they dont. Spasso do U have stock brakes ?
    Maybe determine the correct fluid pressure can help more people here, They may have problems with brakes and do not even know I think.
  19. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    #19 Philwozza, Sep 16, 2011
    Damusto, I had a truck pull out on me a while ago while on a "spirited" drive.
    While I needed a pretty hard press on the brake pedal I felt in complete control.
    My wife used to drive a Williams Megane (sprint fast) , touch the brakes and your head met the windscreen. Good for her, but I like lots of feel and the Testarossa brakes, while some may want a lighter pedal, for me it is just about right.
    My guess is that on a track while the brakes might get hot, the pedal pressure is just about right IMO.
    I have stock (standard) brakes.
    P
  20. damusto
    damusto Karting
    Jul 27, 2011
    71
    I think I understand what You are trying to say, I do not like new cars also.
    I do like, and I need this brake power "gradation", but it is not the problem.
    The problem is that when I push pedal to the metal, I feel braking but I cant say that it is sharp. Is weaker than in ordinary road sedan, with solid discs.
    The Pantera, which I wrote about earlier, was noticeably sharper, and I didnt push her so much.
  21. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    The Pantera is an American market car where the brake pedal is supposed to be "power brake". The Testarossa is a thoroughbred GT/racer and so there is more feel but as you see it, a much heavier feel. I think you just have to get used to it. IMO
    P
  22. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #22 2NA, Sep 16, 2011
    I see a lot of bad advice being given here.
    Robbie (Mr Chairman) has a pretty good approach.
    Start by trying to bleed the brakes. If the brake hoses are still original they are a likely cause. Over time the interior of the hose breaks down and constricts flow. When you open a bleeder screw there should be free flow of fluid out, if not there's your problem. Typically there's no symptom on the outside of the hose.
    Another possibility is low vacuum at the brake booster caused by a collapsed or leaking vacuum hose or bad (leaking) check valve (#5) . Check the vacuum at the booster with engine running.
    Stuck pistons aren't impossible but less likely.
    Forget measuring "brake pressure". :rolleyes:
  23. Testa-rossa
    Testa-rossa Karting
    Aug 21, 2010
    61
    The Netherlands
    Martijn
    Then take it to the track and drive it hard, not grandma style. After a couple of rounds you change your opinion for sure.....
    N17RO likes this.
  24. damusto
    damusto Karting
    Jul 27, 2011
    71
    #24 damusto, Sep 16, 2011
    OK thanks a lot I will start searching tomorrow around noon, we will see whats the problem.
    Testa-rossa could U please give me some track alignment advice (in the meantime). Others also, of course.
  25. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    My brakes are stock.
    New pads were installed and the entire system was flushed in 2005.
    I make regular drives in the mountains around here and on numerous occasions I have braked hard from 100 MPH to 40 MPH with enough force to throw me forward into the belts.
    With that said, because I have STOCK brakes and I did this repeatedly the brakes would fade in short order. I believe this is what some posters are alluding to.
    I would not even consider tracking this car with stock brakes. They would be overheated in a couple of laps.
