Requesting advice from a Plumber | FerrariChat
Discussion in 'Other Off Topic Forum' started by Wade, Dec 27, 2010.
  1. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #1 Wade, Dec 27, 2010
    Any idea what's going on with this valve? Should it be replaced?
    I have two hot water heaters with shut-off valves, both are "corroding" like the one in the picture. Both were installed in 2007, neither are leaking.
    I could replace them myself but can't seem to find the time lately. The quote is over $300 for replacing both (which seems high).
    To anyone who has experience with this, please chime in!
    Thanks in advance.
  2. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #2 Wade, Dec 27, 2010
  3. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    Yikes, sorry no help here :eek:
    Uro?
    ...wrong plumber. :eek:
  4. UroTrash
    Jan 20, 2004
    40,477
    Purgatory
    Clifford Gunboat
    Looks like battery acid!
  5. GuyIncognito
    99,790
    is that calcium buildup on the *outside* of the pipe?
    if so what does the inside look like?
  6. UroTrash
    Jan 20, 2004
    40,477
    Purgatory
    Clifford Gunboat
    Maybe a slow leak, so slow there was no drip but the H2O evaporated leaving the calcium behind?
  7. 308steve
    308steve Formula Junior
    Sep 5, 2010
    304
    Are you on a well or city water? If city water change these out as soon as possible as there is no doubt a leak is causing this. If on a well I'd be very concerned as to the hot water tanks condition. Either case change them out ASAP. Also - have you grounded the pipe? If not you may wish to do so to prevent electrolysis.
  8. LOLAF1RACER
    LOLAF1RACER Formula Junior
    Jun 2, 2007
    497
    Andy
    looks like you had or have a small pinhole leak on the water line going to your hot water heater , we just had this exact condition last week . it was a seepage and calcium build up on the copper pipe
  9. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Thanks for the replies...
    At this point, it appears to be a bad case of surface corrosion (I wish).
    I'm familiar with corrosion from leaks and dissimilar metals but am concerned that a simple valve replacement will only lead to a recurring problem.
    We're on city water and bother heaters are electric... and hopefully grounded.
    I bought a "new" house so that I wouldn't have to work on it... rather play in the garage with the Mondial and the Monster instead :)
  10. bigdavyc
    bigdavyc Karting
    Feb 28, 2010
    66
    Tallahassee, FL
    Recently I smelled burning from my hot water heater. THought it was nothing, next morning no hot water.
    Apparently its pretty common for calcium to build up within the hot water heater and on the coils and cause an electrical short. If this is happening on your pipe, imagine what's going on in your water heater.
    More importantly how does one avoid issues like this?
  11. UroTrash
    Jan 20, 2004
    40,477
    Purgatory
    Clifford Gunboat
  12. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Looks like it might be electrolysis. I would add another ground wire, clean up the valves or replace them and see if it returns.
  13. Glassman
    Glassman F1 World Champ
    One hour job including running for parts. Valve is brass, the pipe is copper, that may contribute with the build up on the valve. I have many that corroded in my commercial building. Get a wire brush and clean it off, maybe you don't need to do anything to them.
  14. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,691
    wisconsin/chicago
    bo
    #14 bpu699, Dec 27, 2010
    Looks like you have copper meeting Galvanized metal in the shutoff...best guess. When dissimilar metals meet you get pronounced corrosion. You need to solder in a brass shut off valve. Or, they sell shark bite shutoff valves that just slip on...30$...work great....
    Someone put in a shutoff valve made of thecwrong material...easy fix
  15. HarfooT
    HarfooT Formula Junior
    Sep 28, 2010
    308
    Prince George, BC
    Hugo McLeod
    Don't bother with sharkbites, get a copper-Pex transition, then run Pex plastic pipe the rest of the way... The fewer valves you have in your house, the better. (do you NEED a valve at that location)
    Also, you may have hard water and require a softener... Are you on city or well water?
  16. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,414
    SFPD
    Dirty Harry
    First Post Awesomeness = simply lending a hand to fellow man.
  17. HarfooT
    Sep 28, 2010
    308
    Prince George, BC
    Hugo McLeod
    Yup, awesomeness... (just helping out a fellow Mondi owner!!!)
  18. bpu699
    Dec 9, 2003
    17,691
    wisconsin/chicago
    bo
    I love PEX. But that will require buying a crimper, soldering on attachements, and then running PEX. Sharkbites are perfect for this application, can be done by the homeowner, and are relatively cheap...
    Also, PEX is not code in many states...Sharkbites are.
  19. kevfla
    kevfla Formula 3
    Nov 20, 2003
    2,086
    gone 4 good
    Hi Wade,
    How's the temperature out on the eastside?
    Noting that you bought a new house in 2007, made me wonder if you aren't a victim of Chinese drywall. Take a look at the copper coils in your a/c air-handler that might be next to your water heater. Are they showing similar signs of tarnishing? Do you notice a rotten-egg odor?
    Your home was built at a time when there was a shortage of domestic drywall and builders, looking to increase profit margins, turned to the imported stuff that has an extremely high sulfer content.
    You need to investigate this ASAP!
    KevFla
    (downtown) Orlando
  20. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #20 Wade, Dec 28, 2010
    KevFla, yes, we're a bit warmer out here ;) Thanks for the tip on the CDW, but we specifically looked for that during the pre-purchase inspection. Turns out, the house was custom built by a builder (for himself) and he went pretty high end for most of everything; no CDW was found.
    I've never heard of SharkBites until you guys mentioned it here... now, after reviewing their website and conferring with some experienced coworkers... I'm hooked! As they said, "Overbuilt is an Understatement". But, the minimum 1" required might be a problem at the wall end...
  21. bpu699
    Dec 9, 2003
    17,691
    wisconsin/chicago
    bo
    Sharkbites are awesome... amazing invention, and reusable!!!
  22. venusone
    venusone F1 Rookie
    Mar 20, 2004
    3,238
    I would think oteoporosis will not be a problem in old age in this house.
  23. Lee in Texas
    Lee in Texas Formula Junior
    Oct 21, 2006
    685
    near Austin, TX
    Lee
    A valve at that location is a very good idea. If the water heater ever leaks and he doesn't have a valve, he'll have to shut off the water to the entire house until a plumber can get out there.
    IMHO, 300 bucks seems like a fair price for changing out 2 shutoffs. A licensed plumber has the tools, knowledge, and insurance. If he (or she) creates a problem, their insurance fixes it. If a home owner creates a problem, their insurance company might deny coverage. Water damage can run into tens of thousands of dollars.
    I can't say what caused the corrosion, but I can say that a water softener is a very good thing to have. It prevents mineral buildup inside your pipes, faucets shower heads, etc.
  24. HarfooT
    Sep 28, 2010
    308
    Prince George, BC
    Hugo McLeod
    Actually, even if the home owner is the one that causes the water damage, they will still be covered.
