Required modification to OBDII Connector | FerrariChat
Discussion in '360/430' started by albkid, May 15, 2020.
  1. albkid
    albkid Formula Junior
    Jul 1, 2016
    318
    Jim
  2. RedNeck
    RedNeck F1 World Champ
    12,169
    The CSA
    Me
    I did it to mine, just requires another ground to be spliced in. Made no difference as far as I can tell.
  3. f355spider
    f355spider F1 World Champ
    18,041
    Yes, all Ferraris prior to the cut off day in 2005 need to have this performed. I had it done on my 1997 F355 spider back in 2006. Without the added ground wire, you may have connection issues using a generic OBDII code reader, or any other type reader that uses the OBDII port. It appears Ferrari did this intentionally to make it more difficult for third party service providers or DIYers. The problem was that by doing so, it was in violation of the law, and also made it difficult for state run emission check stations to connect through the port. Just get it done, it is free, or you can do it yourself using the Ferrari bulletin for instructions.
    Call your local dealer, give them your VIN and they can check if it has been performed previously on your car.
  4. Skidkid
    Skidkid F1 Veteran
    9,502
    Campbell, CA
    John Zornes
    It is campaign 148 as I recall. The original OBD plug didn't have a required ground pin connected. The SD works fine because it gets the gnd from the tester. BUT many smog stations will fail without this connection. I posted the campaign details years ago. Search for my post and you will find it.
  5. f355spider
    18,041
    I've posted it as least 6 or 7 times in the past dozen years or so. Here it is again:
