research on headlamp covers for Dino 206/246 GT/GTS | FerrariChat
Discussion in '206/246' started by GermanDino, Oct 2, 2010.
  1. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,488
    Germany
    Matthias
    I have been recently to Maranello to do some research about Ferrari Dino. Regarding the headlamp covers I was quite keen to find out what is actually fact.
    Regarding the 246 GTS US-Modell #04234 delivered with "protezioni in plastica" it is to say, that is option has nothing to do with headlamp covers. It´s an option, that came only with deliveries to the USA. This option is a protection for the car, to reduce risk of damage during shipping to the States.
    I met some expierenced guys who worked at Ferrari and Scaglietti in the early 70ies and all told me no headlamp covers were fitted with Ferrari Dinos 206/246 GT/GTS in the factory. One reason was bad expierence with Ferrari 275 GTB in the past.
    Regards Matthias
  2. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    The plastic protection is seen in several vintage factory photos and generally covering the bumper areas.
    As for the headlight covers themselves, the 206 prototypes tested with covers in place.
  3. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    correct Shawn, only tested on prototypes, no fitting on production cars at the factory, fittings have been done by importer or dealerships only
    Regards Matthias
  4. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    Seeing as most cars that had them "in period" received the Maranello Concessionaires, it makes me wonder what caused them to install them, other than what was perceived as a cosmetic upgrade. Any idea where they got them from or who made them? Was is Ferrari?
    Did you find out any other super secret info?
  5. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    Unlikely it was Ferrari....
    Nose bars were fitted at the factory in very few cases. It seems some have been fitted at the factory and some with dealerships. Makes sence, as we found different versions...
    Regards Matthias
  6. racerboy9
    racerboy9 F1 Rookie
    2,645
    Any idea what the "factory" nose bars look like? My 1974 GTS came with a nose bar that has a cross section like an air foil instead of just round tubing.
  7. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    Please post a picture of your nose bar. The picture attached shows a nose bar which could be a factory fitted one.
    Regards Matthias
  8. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    #8 GermanDino, Oct 4, 2010
    here the picture (#00350)
  9. 2GT
    2GT Formula 3
    Aug 25, 2008
    1,842
    Western NY
    Fred
    I always thought it ironic that Great Britain, with its large amounts of rainfall and high humidity, has the largest number of headlamp-cover Dinos. When I got mine in 1999, Brenda Vernor in Maranello called Maranello Concessionaires searching for them. They, in turn, referred her to Egidio Brandoli outside Maranello, from whom I ultimately purchased them. Fred
  10. BigTex
    79,380
    Houston, Texas
    Bubba
    We've seen a North American Dino sold recently, that showed the covers as an option, and shipped loose in the car???
    They were illegal to mount, at the time....
  11. swift53
    swift53 F1 Veteran
    8,286
    E.S.
    Alberto
    #11 swift53, Oct 5, 2010
    Just bought a set from Superformance and Colin said that they are the ones F. sells.
    The brackets are really nice and were copied from an "original installation". Really clean set up, and even if anyone thinks it is not kosher, I think it is great as you only drill one hole for the front screw. The rear brackets, are mounted behind the headlamp. Have not yet put it against the car, but will one of these days...
    Regards, Alberto
