Reset ECU's for high altitude - Fact or myth? | FerrariChat
Discussion in '360/430' started by Fast_ian, Mar 13, 2007.
  1. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Hi,
    Many moons ago 'someone' (can't remember who) said it was a good idea to shut off the battery, wait a few minutes, reconnect, start the car and let it idle for 'about 5 minutes' if running at altitude (read - The Virginia City hillclimb).
    This supposedly 'remaps' the ECU's for this thinner air, and I've been doing that at the hill for the past few years - No ill effects. [Although I can't say I've noticed any positive effects either! :) ]
    However, I have a sneaking suspicion this may be an urban myth - Seems like the ECU's are monitoring pretty much everything anyway so would do it "automagically".
    Comments?
    Cheers,
    Ian
  2. RayJohns
    RayJohns F1 Veteran
    7,819
    West Coast
    Ray
    seems fairly reasonable to me. The density of air can have major impacts on an engine's performance, etc.
    Ray
  3. RenoCS
    RenoCS Karting
    Oct 30, 2006
    83
    Reno, NV
    Robert J
    Live in Reno and I just recently had my ECU'S reflashed by the dealer (FoSF). At cold start my CS would run very rough. I would have to turn the engine off and repeat a few times to smooth the idle out. This problem only occured at high altitude in the winter time. The reflashing fixed the problem.
    I'm not sure how the battery disconnect procedure would have worked. Never tyried it!
  4. fuse
    fuse Formula Junior
    Aug 11, 2004
    340
    I was told by my dealer that Enzo and CS needs to idle for 15-20 mins in order to calibrate baseline parameters if the battery is ever disconnected.
    My friend had purchased a set of Hyperflow for his CS and after installation, it was clearly running very rich and the performance gain was minimal. I had him disconnect the battery over night and reconnected it, start the car and idled for 20 mins. After the procedure, the car ran much better. After a few more drives the ECU continued to learn and the car is clearly faster and more powerful than his 2nd CS.
    These procedure are very common and have been true on BMW and Subaru...and I am sure many other automakers.
  5. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    It makes sense, the car 're-learns' the new parameters such as ignition advance, fuel octane rating, etc. This approach simply speeds up the process, if it had to re-learn from such a drastic change such as fuel-air ratio being so different (different atmosphere conditions, sea level, etc. will effect the amount of oxygen in air) it *WILL* eventually 're-learn', however it will just take longer to do so if it didnt 'forget' its learned parameters......
  6. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,677
    LA & OKC
    Kevin
    Generally after most performance modifications or drastic altitude changes you want to let the car remap.
  7. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Hi,
    Firstly, many thanks to those who responded - It's appreciated.
    It seems the consensus is that a disconnect followed by an extensive idling period is only going to help - Which does surprise me a little - I thought "modern electronic monitoring systems" would adjust for the different air mass pretty darn quickly - But, then, that's why I asked the question......
    As for how long both periods should be that remains open from 5minutes to overnight for the disconnect and 5-30mins for the idle - My gut feel is to let it idle until at least the coolant gets to temp - It takes a *long* time at idle for the oil temp guage to move. As for the disconneect, I *know* I've seen CEL's disappear after ~10mins, so unless someone comments further I think I'm going to go with that.
    Again, thx for responses,
    Cheers,
    Ian
    PS - I also remember a couple of Rifledriver comments along the lines of "that switch is there for me, not you! - Don't touch!" which is another reason I asked of course :)
  8. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    I think Rifledriver was referring to the idea that if you force a reset on your ECU your effectively 'hiding' or 'losing' if you like all of those fault codes that may have been logged. These are actually vital pieces of information for service centers to check the health of your car and remedy these problem.
    Obviously if there are no faults to report (you can buy a reasonably cheap OBD code reader these days anyway...) then there is no harm in a reset, especially if your doing it for a specific reason and not just to clear 'i.e. hide' a fault code.
    T
  9. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,293
    Colorado
    Dave
    I think it is all BS. I live at 8300 feet. Engine management systems have all the sensors they need to adjust mixture and timing on the run. I have taken cars from 5K to 14K and back without them missing a beat although power is, of course, down just from lack of air. It is true with modern Ferraris that if you disconnect the battery, it takes a while for everything to reboot when refired (including the F1 trans mapping). It has nothing to do with altitude.
    Dave
  10. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    100% agreed - However, there are a *ton* of codes that don't cause the CEL to turn on and which are, presumably, useful in diagnostics (aka - Brian :) I don't know what truly gets 'erased' by this process, or even if it matters.....
    Cheers,
    Ian
  11. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Aha! - The 'contrarian' view at last! :) - Thanks!
    As I said before, "instinct" tells me the computers are on top of pretty much everything in modern cars and I'm inclined to agree with your BS comment. BUT, my question remains - short of reflashing the ECU (which seems extreme, but apparently did the trick) is there any benefit to doing this every time I drive to altitude?
    I'm leaning towards believing the car has done all the adjusting it's going to do by the time I get there - OTOH, maybe it would be different if the car were trailered up..... I just don't know.....
    Cheers,
    Ian
