Rest TPMS on a 575 Maranello | FerrariChat
Discussion in '456/550/575' started by 215MPH, Dec 30, 2020.
  1. 215MPH
    215MPH Karting
    Jun 26, 2007
    175
    Long Island
    Ben
    Hello,
    I am purchasing new rims, 19 inch and along with them installing new TPMS Sensors on all 4. I am putting the original rims and tires in storage bags. How will the sensors be reset after installation, do I just drive around for some time and the system will relearn? Any guidance will be appreciated.
    Kind Regards,
    Ben
  2. tazandjan
    39,170
    Here you go. Or a tech can use an SD2 to calibrate without having to drive and let the system calibrate itself. Make sure you have the tire pressures where you want them. I use 33 psi all around.
  3. 215MPH
    215MPH Karting
    Jun 26, 2007
    175
    Long Island
    Ben
    Thank you, glad to know I can reset myself without taking it to a shop.
    Cheers,
    Ben
  4. tazandjan
    39,170
    mathewr likes this.
  5. 215MPH
    215MPH Karting
    Jun 26, 2007
    175
    Long Island
    Ben
    Damn I just ordered a set unfortunately they are the 433 but the ad does state they are OEM compatible for 2002 - 2006 512M. I will have to return them then. What about if I find a set that is pre-programmed is that ok and not 433?
  6. mathewr
    mathewr F1 Rookie
    Sponsor Rossa Subscribed
    Dec 7, 2011
    2,915
    Deep in the Heart of Texas
    Ferrari Wheel Guru
    Ben,
    Terry is correct as usual. You need RDE-004. 315MHz for USA cars 2002-2005. (The first Ferrari with the TPMS system)
  7. 215MPH
    215MPH Karting
    Jun 26, 2007
    175
    Long Island
    Ben
    Thanks I just order the 315 as recommended and will be returning the 433 ones receiving. As alway I appreciate the advice and support.
    Cheers,
    Ben
